Leak?
Old 07-10-2009, 06:24 PM
birdshooter's Avatar
Leak?
This happens after the truck has sat a bit then is moved.
I don't think it's anything to be alarmed about but... I've got something leaking which appears to be water (clear, no smell) out of the exhaust pipe just after the Cat on the drivers side.
The drip is coming out at the pipe right where the clamp is in the picture. It leaves a 3 or 4" wide puddle then eventually stops. I know its water, but is there a seal or something at the flange which should be preventing or is this normal for condensation to drain here. Am I over reacting on this?
Old 07-10-2009, 06:48 PM
DeereGeff's Avatar
Mine does it too, mine seems to have quite a bit of condensation in the exhaust to me.
Old 07-10-2009, 07:14 PM
Its normal, every exhaust does it.
Old 07-10-2009, 07:47 PM
yah you can make sure that clamp is tight, but there isnt a whole lot else you can do
Old 07-10-2009, 08:30 PM
jetech00001's Avatar
Thumbs up
its normal condensation mine does the same thing it should stop after it gets up to normal operating temp or you could possibly getting condensation from your a/c.
Quick Reply: Leak?
