Project sub upgraded
Old May 12, 2009 | 02:55 AM
  #91
cdiddy4224's Avatar
Originally Posted by Bajalightning
cDiddy, where did you mount your amp??
i mounted both amps on the back wall
Old May 12, 2009 | 06:10 PM
  #92
Bajalightning's Avatar
hmmm, might still do that, just seemed to me like there was very little/no room for amps back there
Old May 12, 2009 | 11:41 PM
  #93
vjhpac's Avatar
Do you have any pics?
Old May 13, 2009 | 06:27 AM
  #94
Black Platinum's Avatar
did you remove the rear seat? If so what is the procedure. Is it the same as the 04-08?
Old May 13, 2009 | 11:46 AM
  #95
cdiddy4224's Avatar
No but give me a few days and i can get some
It required unbloting i think 6 bolts to get access to the back wall...some of the bolts are a p.i.t.a I didnt have an 04-08 so i dont know what was involved in removing the seat
Old May 13, 2009 | 03:08 PM
  #96
bluegreenf150's Avatar
That looks huge. I thought you were concerned about the sub taking up the load flat floor?
Old May 13, 2009 | 09:34 PM
  #97
Thanks cdiddy, we will owe you
Old May 13, 2009 | 09:35 PM
  #98
I've got the instructions to remove the back seat, I'll try to post them soon.
Old May 15, 2009 | 06:47 AM
  #99
Great!
Old Aug 4, 2009 | 12:58 PM
  #100
ferris11's Avatar
Barritia,
had a couple of questions:
1) the grey jump plug that you're using - I used to use those in racing - where did you buy yours and are you using it so that you can have a quick disconnect of the sub?
2) Are you using the factory head unit? If so, are you using a line out converter like an Audiocontrol LC6 or some other device?
3) for the angles on your sub box, did you just screw them in on that angle and use some liquid nails or did you have another way of fastening the box together?
Thanks and really nice work.
Old Aug 4, 2009 | 01:22 PM
  #101
Barritia's Avatar
Originally Posted by ferris11
Barritia,
I purcahsed the grey plug from the shop who fitted my alarm and they wernt cheap but you can get them from here on line. http://www.hifisoundconnection.com/S...d/0/rid/123284
I used a adaptor for the wireing for the plug that plugs into the stock amp so that i can disconnect the box just like i do with standard setup. It's just a female for amp bypass with the wires coming out that are connected to my new amp.
I am not using any type of converter as i tested my levels with a meter and they were just right for low level input into the JL amp.
I used wood glue and long screws and pilot holed everyhole. It took a long while but it aint coming apart. The hardest bit was sealing the wires going inot the box so that air wouldnt leak. also a good idea to silicon the angles inside the box just to be sure that you got it all sealed well.
Old Aug 7, 2009 | 04:36 PM
  #102
sampsonwr's Avatar
Hey Barritia, first I would like to say great job on your install. Can you tell me which of the wires heading to the factory amp are for the signal?
Old Aug 8, 2009 | 04:17 PM
  #103
Barritia's Avatar
give me a bit and i will go out and take a look.
Old Aug 10, 2009 | 12:49 PM
  #104
sampsonwr's Avatar
Thanks I appriciate it
Old Aug 15, 2009 | 07:38 PM
  #105
What is the color to the low level inputs to the sub?
