Initial dyno results for the 2009!
Old Jan 15, 2009 | 02:03 PM
ASEMechanic's Avatar
Thumbs up Initial dyno results for the 2009!
Hey all...
Finally got back from Dyno Tuning the 2009 F150 and needless to say, I AM EXCITED!
The new 2009 F-150 is running awesome and actually looks to be making a little bit more power than the earlier 2004 to 2008 versions.
From what we've found so far, the only major difference under the hood is that the air filter housing has been relocated directly behind the driver's headlight and now uses a LARGE 12" x 12" pleated panel filter. This is definitely helping airflow.
As you well know, the new platform sports a new 6-speed automatic transmission which now has its own controller which is separate from the ECM. The ECM itself has been updated to a new, faster processor as well. Fortunately, the tuning is quite similar and we were able to get the base tuning done without any difficulty. Here are the preliminary results:
Test Conditions:
  • Vehicle - 2009 F-150
  • Engine - 5.4L
  • Transmission - 6-Speed Automatic
  • Gear - 3.73
  • Fuel - 85 Octane
  • Altitude - 4500 Feet
  • Ambient Temp - 76º F.
  • Barometric Pr. - 26.65 In. Hg. (absolute)
Here are the dyno plots (Click on the images to view full size):
Horsepower Only
Torque Only
Horsepower and Torque
Horsepower, Torque and AFR
As you can see, the biggest gains were not on the top end but in the midrange... which is where you really need it! Notice that the stock AFR curve does not allow any WOT enrichment until about 4500 RPM! And you wonder why the trucks are always so sluggish off the line. The AFR stays right at 14.6:1 throughout most of the acceleration. Now add a Cold Air Intake which in most cases cause a slight to moderate lean condition and suddenly you have a situation that could be very detrimental to the engine.
I also included an additional dyno plot which shows without question that removing the snorkel does, in fact, improve the performance of the vehicle, particularly above 3500 RPM. Based on calculations, removing the snorkel picked up 7.5 HP and 7.6 Ft./Lbs. These figures are very respectable, especially considering that we had already made a significant gain with tuning. Unfortunately, I didn't have time to retest the vehicle with the Performance calibration, but I would certainly expect to see similar improvements with the same modification.
Needless to say, we are really excited about the results, especially since we only ran 85 Octane fuel. We will be doing some (relatively) sea-level testing here in the next week or two along with 93 Octane fuel testing and fully expect to see even better results.
We'll keep everyone posted on the results as development progresses. Stay tuned...
Last edited by ASEMechanic; Jan 17, 2009 at 01:59 PM. Reason: Corrected Baro Pressure value
Old Jan 15, 2009 | 02:08 PM
Good work Bill! Thanks for posting.
Old Jan 15, 2009 | 02:26 PM
yetti96's Avatar
85 octane? I thought 87 was the lowest available..hmm
Old Jan 15, 2009 | 02:33 PM
trolls56's Avatar
Have you done any dyno runs with E85?
Old Jan 15, 2009 | 03:02 PM
Smokewagun's Avatar
No, it depends on where you live. I run 93 octane most all the time, and when I frequent Northern Wisconsin, I have to change tunes because only 91 octane is available where I go up there.
That's because you're in Florida. In Utah, octane is commonly 85, 87 and 89, with 91 floating around from time to time. This is because higher altitudes don't require fuel with as much octane as sea level.
As for the E85, even though the test vehicle we used was a Flex-Fuel, I did not have the opportunity to test the E85 fuel. There is actually very little E85 where we tested so it wasn't really a consideration at this point.
Old Jan 15, 2009 | 06:54 PM
blackf-150's Avatar
So are u thinking that an CAI on the 09 is not needed or may be not good for the engine, the stock intake is a mess the way it looks with all the plastic and the routing, what is your take on it????? Thanx for the dyno post.
Old Jan 15, 2009 | 07:29 PM
Barritia's Avatar
Yeah whats the deal with all the knobly bits and funny shape things sticking out of the intake? I was thinking that the other day.
Old Jan 15, 2009 | 08:01 PM
The knobly bits are Helmholtz filters used to eliminate the droning commonly associated with Cold Air Intakes. Obviously, it's not pretty looking but I am a function over form type of person. I don't particularly care what it looks like as long as it functions properly. Other folks have a different opinion and might prefer the cleaner look of a CAI. It's all personal preference at that point.
I'm not necessarily saying that a CAI is bad for the engine, but my concern is the fact that the AFR is already starting out at a dead 14.6 to 1 and historically CAIs cause the engine to run even leaner. I certainly wouldn't be running a CAI without appropriate tuning to correct any resultant lean problems, especially when I can pick up 7+ HP with a simple, free modification.
Old Jan 15, 2009 | 08:08 PM
Barritia's Avatar
Well that interesting. I can now make out to people i know what im talking about when they ask me what those funny looking things are sticking out of the intake pipe lol.
Old Jan 15, 2009 | 08:19 PM
CometFlash's Avatar
Question
::complete engine idiot here::
1) What is the snorkel?
2) What is it's purpose? (eg why did Ford put it there it must be there for some reason?)
3) And would it be easy to remove?
Thanks!
Old Jan 15, 2009 | 10:39 PM
Jeff H's Avatar
what is droning?
Old Jan 15, 2009 | 11:34 PM
blackf-150's Avatar
Thanx much for the info, are u familiar with the 04-08 5.4 intake system could the snorkel be removed on them say where it goes into the inner fender well, my 04 5.4 is bone stock except for a cat back magnaflow exhaust just looking for a little bit more umph????
Old Jan 15, 2009 | 11:41 PM
How do I explain droning? That's a tough one. If you familiar at all with older cars with 4 barrel carbs, it sounds like the noise made when the secondaries opened up when you floor it. It not really a whine as it is much lower pitched. Maybe sort of like a cow mooing endlessly.
The snorkel is something like this (picture courtesy of the "Gotts Mod" thread https://www.f150online.com/forums/ex...t=gotts+intake)
This modification works on basically any 1997 and later. The filter arrangement is different, but they all use a snorkel to pull air from the fenderwell.
The reason it's used is to help smoothly curve airflow into the air box. The problem is that it is also the smallest diameter portion of the entire intake system. The one on the 2009 is part of the airbox, but pops out rather easily. Ford got a little smart on this one and actually perforated the snorkel so it looks a little like a Whiffle ball but as the dyno plot shows, it still is a bit restrictive. Go figure.
Old Jan 15, 2009 | 11:44 PM
Complete with Gotts feet.
