Lariat Gauge Cluster In XLT 05
Old 07-23-2022, 11:41 PM
WolfMxbee's Avatar
Hi so I looked around and People on said they wire a switch or wire constant power which cause issues. Anyways so I did the cluster swap and don't have any codes with in my cluster with my scanner, only climate control circuit but my AC will not turn on because of the cluster the fact that the lariat has only auto ac and mine is manual so it needs a signal through the climate control, replace all relays, sensors and fuses and all are good, no leaks at all, had it pressure checked and recharged and had exactly what my 05 requires following the conversion from ounces to lbs, anyways is there any fix for this as I don't believe in having the clutch wired at all times to straight power as it'll overcharge and lead to damages
Quick Reply: Lariat Gauge Cluster In XLT 05
