Lifted Trucks - Tie Rod Interchangeable?
Old May 31, 2022 | 07:59 PM
WolfMxbee's Avatar
So I've been doing research and am currently getting some extended spindles for my truck to correct some geometry issues, I do not like the angle of the tierods with a 2.5" leveling kit, so I have done research on 2015 2009-2019 Tie Rods and the specs for 09-19 are the same, if I'm theoretically correct then the Tie rod Heim joint spacers will fit our models as well, factory 09-19 tie rod ends are angle to run along the sides of the inners compared to the 04-08 where it runs parallel to the inners, however aftermarket 09-19 offroad/heavy duty tie rod ends run parallel, give me your inputs
2009-2019 specs
2004-2008 F150 specs
Old May 31, 2022 | 10:28 PM
tbear853's Avatar
What are you trying to fix?
