Just picked up an 08 F150 FX4, but the external temperature gauge reading in C, not F
Old Apr 10, 2020 | 11:31 PM
BlackReef's Avatar
Its reading in Celsius, not Fahrenheit for the outside temperature. It appears on the small odometer message display in the dash. My truck just has the mini message center.
The owners manual says to hold some HVAC buttons to change it, but my truck has the manual climate dials. How do I change temp display to Fahrenheit? Thank you
Old Apr 11, 2020 | 05:20 PM
projectSHO89's Avatar
You're looking in the wrong section of the owner's manual... See the section for the mini message center.
Old Apr 11, 2020 | 09:35 PM
BlackReef's Avatar
Sadly it does not say where to switch from C to F on the external temp display.
Old Apr 11, 2020 | 10:36 PM
Is everything else correct - miles and not km?
Old Apr 12, 2020 | 01:36 AM
BlackReef's Avatar
Thanks but those directions are for the regular message center with the three console buttons, which my truck does not have. I just have the mini message center and no buttons. I found in the manual it says I have to see a Ford dealer to have it fixed smh.
Old Apr 12, 2020 | 08:24 AM
Then you have your answer.
Old Apr 12, 2020 | 10:16 AM
Is it possible you might be able to do that with Forscan?
Old Apr 12, 2020 | 12:07 PM
BlackReef's Avatar
yea, from what I read FORSCAN is the only option besides going to the dealer. How exactly does that work, I need to buy my own OBDII scanner, and then install the software? Not too familiar with it. Thanks man
Old Apr 12, 2020 | 01:14 PM
https://forscan.org/home.html
  • Supported adapters :
  • OBDLink EX, recommended USB adapter for Windows version of FORScan, also for configuration and programming functions
  • OBDLink MX+, recommended Bluetooth adapter for Lite versions of FORScan (iOS, Android)
  • OBDLink SX/LX/MX
  • ELS27 (STN1170/2120)
  • ELM327-compatible (fully compatible with original ELM327, such as
    VeePeak VeePeak
    , please also see important note below)
  • J2534 Pass-Thru
  • CANtieCAR (in "FORScan" mode)
  • Supported platforms:
  • Windows 2000/XP/Vista/7/8/8.1/10 (ELM327-compatible adapters with COM, USB, Bluetooth and WiFi interfaces, J2534 PassThru adapters). Note: only x86 architecture is supported for Windows. ARM architecture is not supported!
  • iOS v7.0 and higher (OBDLink MX+, ELM327 BLE and WiFi adapters)
  • Android v4.0 and higher (ELM327 Bluetooth and WiFi adapters)
https://forscan.org/download.htmlProducts
FORScan for Windows FORScan version 2.3.31 beta for Windows - free
Information about Extended License Buy Extended License: 1 year, 3 years, 5 years or lifelong Get free Extended License - 2 months trial
FORScan Lite for iOS - attention: some functions are missing in FORScan Lite. Please see comparsion of applications FORScan Lite 1.5.6 for iOS (Core 2.3.31) - paid FORScan Viewer for iOS - free, please use it to check compatibility before purchasing FORScan Lite for iOS
FORScan Lite for Android - attention: some functions are missing in FORScan Lite. Please see comparsion of applications FORScan Lite 1.5.6 for Android (Core 2.3.31) - paid FORScan Demo for Android - free, please use it to check compatibility before purchasing FORScan Lite for Android
"><img src=" /> ">
Buy Bluetooth adapter for Android on Amazon Buy Bluetooth adapter for Android on Amazon
(US only). Please use this discount code: FORSCAN20MX
Old Jul 20, 2020 | 04:40 PM
Mike Goodsell's Avatar
Ford Pass App
Downloaded the app on my I phone and the temperature is on Celsius ? Anyone know how to change that ?
Old Jul 20, 2020 | 07:07 PM
What are you working on, Mike? Please be more descriptive.
Are you trying to use Forscan? Do you have a compatible OBD2 adapter? You may need the Windows version to do what you need.
