intake manifold coolant crossover leak
Old Feb 18, 2020 | 02:45 PM
normal's Avatar
I'm wondering if there is any risk of damage by driving with a seeping, slow leak at the coolant crossover (below thermostat housing) provided that coolant levels are closely monitored and maintained?
Note: I'd prefer to wait for summer to fix, but not at risk of any collateral damage. Truck runs perfectly, no misfires and at proper temps (edge monitor), and oil and coolant look / smell proper. I know I run risk of coolant dripping into plug wells (which may develop misfires), but can't think of anything else. Appreciate any feedback people may have.
kw: intake manifold gasket gaskets coolant crossover cross over antifreeze thermostat housing oring 4.6 5.4 v8
Old Feb 18, 2020 | 06:40 PM
tbear853's Avatar
Sounds like you have a good understanding, you've covered the bases. I'm sure many have run a long ways with the owner having no clue, until the coolant is too low and it overheats one day.
Keep an eye on coolant & plug wells, any that finds it's way into the valley has an escape route out the back of the block. You could even blow out the plug wells occasionally.
Old Sep 18, 2021 | 03:59 PM
SiskCFRN's Avatar
My 08 did that in 2017 with maybe 175,000 miles on it, except I had no idea there was a leak until the truck started bucking & skipping right after I floored the accelerator. Like the previous commentator said, no telling how long it had been leaking before it reached that point.
