Suggested maintenance on 2008 fx4 with 135k miles
Old 08-08-2018, 11:58 AM
Jayvaughn74's Avatar
rear differential fluid leak
based on the attached pics, what is the most suspect area of the rear differential fluid leak?
for the fluid to be slung up against the bottom of the bed (as seen in the pics), it would imply the oil is either leaking or making it's way to that linkage that spins (sorry i don't know the name of it)..
Could there be a leak in that specific area OR is it coming form the differential cover and finding its way back to the spinning area? there is obvious wet oil at the differential cover... but is it leaking from there or the spinning linkage area?
is there a common place for this to leak at in this area?
I'm about to do a fluid change and make sure I address any issues at same time... hoping it is coming from the differential cover and the not some seal in the linkage area.
Old 08-08-2018, 12:08 PM
That is coming from the axle seal and is getting slung around with the u-joint and shaft.
You'll want to get that corrected before wasting money and polluting the environment. A competent shop that works on rear ends should be able to fix that rather quickly for around $150 in labor and $30 in parts... more or less depending on who you have working on your vehicle and going local shop rates.
Old 08-08-2018, 12:18 PM
Thank you. That's what I was afraid of but explains my spinning rear tires when it's been raining.
Old 08-08-2018, 12:27 PM
Roadie's Avatar
Axle seal leak? Looks like the pinion seal is leaking to me.
Old 08-08-2018, 01:05 PM
agree - just familiarized myself with a youtube video on repairing both and definitely the pinion seal is leaking.
Old 08-08-2018, 01:06 PM
glc is offline
Parts stores probably don't have XL-3 or XL-12, it's online or at a Ford dealer only. Parts stores may have something supposedly compatible, but for these 2 items you should get the genuine Motorcraft stuff. For gear lube any brand is fine, even Walmart Supertech.
Old 08-08-2018, 05:20 PM
Roadie's Avatar
Since the transmission will leak trans fluid into the transfer case, I suspect trans fluid won't hurt it. Is XL-12 the new spec for Mercon?
Old 08-08-2018, 07:31 PM
glc is offline
XL-12 is the specific fluid for Ford transfer cases, it's similar to the old discontinued Mercon, They have found that Mercon V is not good for transfer cases.
If the transmission leaks into the transfer case, you have a seal that needs replacing, sooner rather than later.
Old 08-27-2018, 06:54 PM
Originally Posted by glc
Early 2008 still had the 2 piece plugs, late 2008 went to a different head design with conventional plugs. If your COP boots are black, old style - brown, new style.
I use rockauto.com for parts.
It doesn't pay to buy differenitial oil online, shipping will kill you. Buy it locally. Diff covers don't use gaskets, you use RTV. Rear diff takes 75W140 full synthetic, if it's limited slip, add one 4 oz bottle of XL-3 additive from the Ford dealer, it's not expensive, I think I paid about 6 bucks last time I bought it. Front takes 80W90 conventional or 75W90 synthetic, no additive. Transfer case uses Ford XL-12 fluid, don't use ATF. XL-12 is 14 bucks a quart from Amazon with free shipping if you buy 2 or more, I don't know how much your dealer would charge.
so taking on the spark plug change myself. Ordered my plugs, boots, and motor craft carb cleaner. However my boots are black not brown.. so is there any other way to determine if my plugs have been changed before I took possession of vehicle?
Old 08-27-2018, 08:43 PM
glc is offline
Not until you pull them unless you have maintenance history.
Old 08-30-2018, 06:16 PM
What are the codes?
I'd change the spark plugs unless you know for a fact they have been changed in the last 50k miles. Valves cannot be adjusted, if you hear ticking you are starting to develop cam phaser issues.
Would not hurt to change the diff and transfer case fluids.
alrighty. Ordered all my parts for new plugs.
Sp546 plugs, new boots, and carb spray.
Took my first plug out and its is some ngk plug and when I looked it up it was coming in Ford mustangs.
I bought this truck several years ago from a corner car lot in another state and paid $18k with every intention of buying a Ford F-150.
How is is the best way to validate this engine is indeed an f150? Everything I see says it is but what about the block?
Appreciate any advice and where I should go from here.
Old 08-30-2018, 06:56 PM
glc is offline
You have a late 2008 engine. You need SP509's. You also need different boots.
Old 08-30-2018, 07:09 PM
Glc, thx! I freaked and in fact just came to same conclusion you stated and just ordered my 509's on amazon. New boots too? Bummer. Ok thx again!
Old 08-31-2018, 10:24 AM
are you sure i need different boots? the one's i got (in link below) are identical in every way to the ones that came out aside from the black vs brown boot cover.
I'd certainly like to go ahead and use these to finish up the job if I can.
Amazon Amazon
Old 08-31-2018, 12:52 PM
glc is offline
Do not replace the whole coil. Those Chinese coils you bought are junk. I suggested you replace just the boots on the original coils. They are sold as boot and spring kits. Check to make sure these fit:
https://www.rockauto.com/en/parts/st...lug+boot,10150
For now, just clean up what you have and use dielectric grease.
Quick Reply: Suggested maintenance on 2008 fx4 with 135k miles
