2006 Texas Edition Questions
Old Mar 7, 2018 | 08:49 PM
W vin is 4.6 2 valve.
With that many miles, it could be a number of things. I think I'd start with pulling the spark plugs and doing a compression test. If any cylinders are low, you just bought a truck that needs an engine rebuild. If it's good, put a new set of Motorcraft plugs in it. Before putting the coils back on, I'd change the boots and springs, it's possible you may need one or more new coils, use Motorcraft, Denso, or Delphi. Make sure you put some dielectric grease in the boots. Put some Techron in the gas to clean the injectors. Check for vacuum leaks.
Check the OBD2 with a code reader or scan tool for any codes.
Old Mar 7, 2018 | 08:51 PM
vroom_vroom's Avatar
Originally Posted by glc
NEGATIVE.
There were 3 engines available in 2006. The 4.2 V6 and 4.6 2 valve do not have VCT. The 5.4 3 valve does.
What is the 8th character in your VIN?NEGATIVE again. The only F-series Triton engines that have VCT are the 4.6 3 valve (2009 and 2010 only) and 5.4 3 valve (2004-2010). The 6.8 V10 does not, even the 3 valve.
If it's shaking at idle, it may need new spark plugs and/or coils or it may have dirty fuel injectors. How many miles on it and do you have any maintenance history?
This is why I don't listen to my pops and his 4.6.......... thanks for the correct info
Old Mar 7, 2018 | 08:52 PM
rdb1953's Avatar
Do you know what the compression PSI needs to be at ?
Old Mar 7, 2018 | 10:13 PM
You are looking for consistency, not absolute numbers. Any cylinder that's more than 15% under the highest reading is not healthy.
