Flush Engine Coolant
Old Aug 23, 2017 | 02:10 AM
Ford Truck 07's Avatar
Neer instructions to flusch coolants on 2007 FORD F150 5.4 Triton 4X4 also locations of Engine drain plugs
Old Aug 30, 2017 | 12:39 PM
carioux2008's Avatar
The drain plug is on the bottom corner of your radiator. Its a good time to replace your thermostat as well. Good luck!
Attached Thumbnails Flush Engine Coolant-1.png   Flush Engine Coolant-2.png   Flush Engine Coolant-3.png
Old Aug 30, 2017 | 03:06 PM
A RADKITPLUS costs $200, it's a professional tool. I'd use one of these, no need to try to pull the block plug.
Amazon Amazon
Old Nov 5, 2017 | 06:36 PM
aqua-holic's Avatar
Can some post up on how to use the flush kit. I'm pretty mechanical and couple years ago i had looked at it and read the directions and man they confused the crap out a me. If i remember you have to cut some hoses and it stays installed after the flush (???)
Anyone ​​​got some pics or a how to on it.
Old Nov 5, 2017 | 06:44 PM
You install the tee in the heater inlet hose.
Google it, there are a couple YouTube videos.
