Starter Woes... Plz Help
Old Jan 31, 2017 | 04:12 PM
random155's Avatar
So I found the neutral safety switch. But my question still stands. How can this be the culprit if when the truck doesnt start, if I bang on the starter with a hammer, the truck starts. Also, if the truck doesnt start I roll it forward about a foot it starts.
Old Feb 2, 2017 | 07:52 PM
random155's Avatar
Ok, so I tested he neutral theory tonight. The truck wouldnt start, but after I put it in neutral it fired right up. Im still confused though about why it will also start if I bang on the transmission. Anyone know the correct part number for a neutral safety switch / transmission range sensor for an 04 f150 FX4 5.4 liter?
Old Feb 2, 2017 | 08:34 PM
F6DB-14A464-RA
MOTORCRAFT SW5713
$49.79 at rockauto.com
Old Feb 2, 2017 | 09:04 PM
random155's Avatar
Originally Posted by glc
F6DB-14A464-RA
MOTORCRAFT SW5713
Thank you sir. Im trying to find an aftermarket cheaper alternative, but Im having difficulty. I get several options, like 14 or 20 bold trans, etc.
Old Feb 2, 2017 | 09:30 PM
random155's Avatar
That part isnt showing that its the correct part for my truck. This is so annoying. Everywhere I look there is no 100% certain part.
Old Feb 2, 2017 | 11:11 PM
Contact Tasca with your VIN, you will get the right OEM part at wholesale.
Yours MIGHT just be slightly out of adjustment.
Old Feb 3, 2017 | 07:31 AM
random155's Avatar
Ill mess around with it today. There are surprisingly few details about these little guys. How can I tell if its out of adjust/alignment?
Old Feb 3, 2017 | 04:37 PM
random155's Avatar
F6DB-14A464-RA
MOTORCRAFT SW5713
Alright, ordered from rock auto. Any tips on getting this lined up and installed correctly?
Old Feb 3, 2017 | 05:35 PM
With vehicle safely secured, place ignition switch to RUN, shift lever to Reverse. Loosen the DTR switch and with the aid of a mirror (or an assistant), adjust the DTR switch so the backup lights are on, then tighten the switch. That will usually fix any misalignment issues.
Old Feb 3, 2017 | 06:22 PM
random155's Avatar
Gotcha, thanks
Old Feb 8, 2017 | 12:10 PM
random155's Avatar
Well, I replaced the neutral safety switch / transmission range sensor today. That thing was practically welded on their. Not too bad of a job, but I guess we'll see what happens.
