5.4 3v v8 what is this?
Old Nov 15, 2016 | 02:58 PM
Battlewar5.4's Avatar
I'm wondering what this hose does? I'm new to this engine and I was checking hoses after I changed the oil. this one was brittle enough to start crumbling in my hand.
any advice would be greatly appreciated.
thanks
Old Nov 15, 2016 | 03:18 PM
thelariat02's Avatar
The A/C line. Looks like suction line.
Old Nov 15, 2016 | 03:27 PM
Would this affect the performance of the engine?
Old Nov 15, 2016 | 05:06 PM
RUSS04's Avatar
You are missing a cap on that ac line.
Old Nov 15, 2016 | 06:06 PM
tbear853's Avatar
No ..... but I'd get a cap for it.
Old Nov 15, 2016 | 06:07 PM
Roadie's Avatar
Autozone sells caps for the shrader valve. Doesn't affect the engine. It is where you connect a gauge to check the low side pressure of the AC and also where you add refrigerant when required.
Old Nov 15, 2016 | 06:20 PM
Sorry, I have the cap, it was just off when I took the picture.
thanks for clarifying what this was so that I could get a new one!
Old Nov 15, 2016 | 11:23 PM
If you have the cap, why do you need a new one?????
Old Nov 15, 2016 | 11:25 PM
I don't need a new cap. I need a new hose.
the black hose crumbled from being dry and brittle.
Old Nov 16, 2016 | 09:11 AM
That is just insulation. Should it be changed, yes. Does it have to be, no. The AC line is the aluminum line the shrader is connected too
Old Nov 16, 2016 | 11:14 PM
Thelariat02 thank you for sharing this with me. I really appreciate the help.
I hope everyone will forgive me but I don't really know how to post on this site or where to post to. I have another question, hopefully someone can tell me what these failed tests mean?
pics attached.
thanks,
Erick
Old Nov 17, 2016 | 01:01 AM
There is no sensor 3, hence the failures. 2 banks, 2 sensors per bank.
Old Nov 17, 2016 | 01:04 PM
Originally Posted by glc
there is no sensor 3, hence the failures. 2 banks, 2 sensors per bank.
x2^
Old Nov 17, 2016 | 02:00 PM
Thanks guys, really good to know!
I was worried about failing a smog check!
Old Nov 17, 2016 | 03:29 PM
tbear853's Avatar
Insulation ..... just wrap it with some good tape and a zip tie.
