fuel odor
Old Aug 8, 2016 | 12:36 PM
butterbean60's Avatar
fuel odor
My 2005 F-150 4X4 w/ 5.4 smells of fuel in the cab specifically after starting and while at idle. Any suggestions would be greatly appreciated.
Old Aug 8, 2016 | 06:40 PM
kcward's Avatar
You didn't by chance recently change the plugs? If so, then re-torque/torque the plugs to 25 ftlbs...that is all I can think of...
Old Aug 8, 2016 | 10:49 PM
Could also be leaky fuel injectors, the 2005 5.4 had a bad batch.
Old Aug 9, 2016 | 12:24 PM
No, just recently bought the Truck. I'll check them though.
Thank you !
Old Aug 9, 2016 | 12:32 PM
Rough idle
I have a 2005 F-150 that occasionally idle rough. If I pat the gas pedal, it seems to clear up at least until the next Red light but this is an occasional occurrence. If I floor it to try to clean it out, the engine light comes on. Disconnect the battery, the engine light goes off and runs fine for a while then it starts going through the same routine.
any ideas ?
Thank You
Old Aug 9, 2016 | 07:11 PM
When the engine light comes on, you have to read out the OBD2 codes, not disconnect the battery!
