04 f-150 5.4
Old Mar 13, 2016 | 05:47 PM
walkingboss60's Avatar
04 f-150 5.4
I have an 04 f-150 with a 5.4 triton. It keeps flashing up a misfire code.First it said misfire on #8 changed all plugs and all coil packs.Still has a misfire and it keeps showing misfire on #5 clear that code out and then it shows misfire on#6 and then at times it flashes code for running lean on bank 1.Any help is greatly appreciated.
Old Mar 13, 2016 | 06:46 PM
Matticus06's Avatar
How many miles on the motor? .. I could be way off or stating the obvious, but were the plugs gapped correctly?
Old Mar 13, 2016 | 07:15 PM
The Plugs are factory set and milage is just over 180,000
Old Mar 13, 2016 | 07:45 PM
What brand plugs and coils did you use? Have you used any injector cleaner in the gas recently? Techron is recommended.
