0mm offset 18x9 rims fit on 2.5 inch leveling kit?
Old Feb 15, 2016 | 09:48 PM
Kevin Jones's Avatar
Hey I have an 07 f150, will 18x9 rims with a 0 offset fit well on 305/65r18 tires? (33.6 inch tires)
Old Feb 20, 2016 | 08:17 PM
They should yes. Maybe minimal trimming on the front valance plastic.
Old Feb 20, 2016 | 08:29 PM
Thanks I appreciate it. Do you know from experience?
Old Feb 20, 2016 | 10:31 PM
Not first hand, but your offset is more of an in-between from my experience. I have +18 offset wheels, and I put 1.5" Bora spacers on, which I calculated at -16 offset. +18 had zero rub, -16 rubs at 3/4 lock on the back fender liner towards the cab.
Old Feb 20, 2016 | 10:43 PM
Oh alright sweet, hopefully it works out. I'm gonna get one mounted on and tested this week before I buy the rest of the set. Thanks for the help
Old Feb 23, 2016 | 12:38 PM
Dolomite's Avatar
It will fit, I know from first hand experience with that exact setup
I was told my truck had a 2.5" level when I got it, but I think it was closer to 2. Either that or the OEM Springs and struts were just way shot. I had minimal rubbing on the fender flares and trimmed it just a tad.
This was before my recent coilover install, you can see the small amount I did on the flare. I trimmed the valance as well.
Pre fender flare and valance trimming, right after I got home with my new wheels
This is after the coilovers which netted me about 2.75" over stock form, if I had these prior to getting the new setup I probably wouldn't have needee to trim at all.
Granted back spacing will have some effect, mine are 5"
Old Feb 23, 2016 | 01:24 PM
Damn dude that looks sick. I think it should be good then. Can you send a few more pictures of your truck? struts and a further away overall view of your truck would be great!
Old Feb 23, 2016 | 01:48 PM
295x70x17 Toyo's (33.5x12) but on 17x9 wheels with 0 degree offset or 5 inches of backspacing. These wheels should be the same as the 18's but one inch smaller in diameter. 2004 Lariat I had that was leveled 2-1/2 inches. No rubbing with these tires and wheels so the 305's on your 18's should be the same.
I had the 295x70x17 Toyo MT's on my '04 Lariat. They were on 17x9 with 0 degree offset American Racing Craters. 33.5x12 and fit perfect on these wheels.
Old Feb 23, 2016 | 02:49 PM
Dolomite's Avatar
The coils are F150Lifts Boss coilovers, I have a thread I recently made that has more pictures of them as well as my thoughts on them. But for the record, they ride absolutely amazing.
Old Feb 24, 2016 | 02:30 PM
Wow yalls trucks look great. Thanks for the help, I'll definitely give it a shot. And even with the 5inch of backspacing your control arms were fine without rub?
Old Feb 24, 2016 | 02:32 PM
This is my truck
Old Feb 24, 2016 | 02:35 PM
Old Feb 28, 2016 | 11:29 AM
Dolomite's Avatar
Definitely needs those 305's
Good looking truck btw!
Old Feb 28, 2016 | 01:57 PM
Thanks brother, I'll post a picture when I get them mounted.
Old Mar 5, 2016 | 04:33 PM
Thankyou everyone for the help
I got my tires and rims put on today, and I couldn't be in more love with it. No rub or anything. 305/65r18 on 18x9 pro comp rims 0 mm offset.
