5.4
Anything is possible if you have enough money and/or the right set of skills. That being said, making the conversion you are contemplating is not a "plug and play" proposition and would likely cost far more than simply buying a used or remanufactured 5.4 3-valve and dropping it into your truck.
As the others stated, it is not recommended.
Just get another 3v 5.4l long block, buy some new parts (alternator, ps pump, etc), and maybe even throw a couple aftermarket parts on... then do a core return on your old block and call it a day.
You'll find yourself in a lot less frustration.
