Trucks Hesitated on Start Up. But only one time.
Old Mar 26, 2015 | 04:34 PM
Script's Avatar
I have a 2006 F-150 STX 4.6L V8 with 64000 miles on it. Only maintenance has been oil changes...
Yesterday after work I went to start my truck and it started but was shaking and couldn't catch any rpm. The engine was turning over but it was experiencing serious low idle and hesitation. I turned it off after a few seconds and gave it another try and it started up as normal with no problems.
I have experienced a little bit of a rough idle at stoplights which I hear is normal, but I have never had any problems starting it like I did the other day.
I have tried starting it today and cannot re-create the problem...
Old Mar 29, 2015 | 09:00 PM
Script's Avatar
Bump
Old Mar 30, 2015 | 09:24 AM
2008_XL's Avatar
Originally Posted by Script
Bump
Check the fpdm for corrosion. At 64k, and being that it's 9 years old, the fuel filter should have been changed at least twice already, air filter a few times, transmission fluid should have been done every 30k, you should change the plugs and cops. That's a good start.
Old Apr 4, 2015 | 09:27 AM
RevBiker's Avatar
Fuel pump driver Module
Old Apr 4, 2015 | 10:21 AM
My truck shakes a hair at a stop in drive, but i'm also still on original plugs/COPs. I chalk up everything to that though. I have replaced my FPRD already.
