Custom Rear Bumper
Old Feb 11, 2015 | 10:03 PM
cgmiller83's Avatar
Custom Rear Bumper
Going to start working on the rear bumper soon. Only when its to cold to work on the front bumper on the truck. This is some pictures of it at different angles using Sketchup. I haven't worked out the brackets to mount it to the truck yet. Only because I haven't looked at how the current bumper is bolted on. Adding brackets later won't effect how the outer shell is designed. Will be made with a mix of 1/4 and 3/16 A36 steel.
Old Feb 13, 2015 | 09:27 AM
maxpat82's Avatar
looking good.
1/4"? damm you want to lay down tree with it?
it's gonna be HEAVY!
,125 would be plenty enough IMO.
Old Feb 13, 2015 | 09:33 AM
Nemisus's Avatar
Very nice concept! Looking forward to seeing a finished product.
One of the top 5 most wanted mods to my 06 lariat are front and rear bumpers. Just don't have the cash to drop on what they cost.
Cheers
Old Feb 13, 2015 | 11:16 AM
Pockets's Avatar
That looks great!
Only thing I would say is shackles somewhere near those lights
Old Feb 13, 2015 | 12:06 PM
I'd rather use a thinner gauge steel and then rub a half pipe brace behind connecting all of it.
Old Feb 13, 2015 | 02:42 PM
ak_cowboy's Avatar
Originally Posted by Pockets
That looks great!
x2 on the shackles.
Making it out of 1/4 will be plenty strong enough. If you're curious about the pipe bumpers, here's mine from Bodyguard.
Here's the backside
Here's the front afterwards. You can see the weld in the middle of the circle and square.
Old Feb 16, 2015 | 10:33 AM
cgmiller83's Avatar
That looks great!
I'm going to put shackles mounts on it. I won't know where until I have the mount made up to bolt to the frame.
Old Feb 16, 2015 | 10:35 AM
cgmiller83's Avatar
Pipe bumpers make it a little hard to add lights to the face of the bumper the way I want.
Old Feb 16, 2015 | 12:41 PM
ak_cowboy's Avatar
absolutely, thats why I had an extra couple inches welded on. regular plate steel is a lot easier in that aspect.
Old Feb 16, 2015 | 03:47 PM
SoonerTruck's Avatar
Copying the newer GM bumper corners, eh?
Old Feb 18, 2015 | 09:44 PM
cgmiller83's Avatar
Well it was to cold this last weekend to weld outside on the front bumper. So I started working on the parts for the rear. Here's how the corner step pockets turned out.
Old Feb 19, 2015 | 08:44 AM
Pockets's Avatar
Cool starting to make progress! Can't wait to see the finished product.
What's with the little hole on them?
Old Feb 19, 2015 | 11:27 AM
tbear853's Avatar
I was thinking maybe he's gonna hang some aux. work or back up lights in them .... protected yet casting some light to sides as well?
Old Feb 19, 2015 | 11:59 AM
cgmiller83's Avatar
The hole is for a light but only a small LED eagle eye. That way you can see where the step is on a very dark night.
Old Feb 19, 2015 | 01:13 PM
Pockets's Avatar
That's exactly what I was thinking they were there for!
How about making them red and having them work with the brake lights?
