Lifters And Rockers?
Old Feb 4, 2015 | 04:30 PM
Simpleaim's Avatar
Hello All,
I getting ready to do the timing set, cam phasers, oil pump and water pump on my 2004 F150 5.4 with 217,000 miles.
I'm wondering if the consensus is if I should also replace rockers and lifters? Is there anything else I should also do while I got it undressed?
I did the spark plugs about 20,000 miles or so ago.
Thank you,
Old Feb 4, 2015 | 04:47 PM
SoonerTruck's Avatar
Inspect them for wear. If they're within tolerances, keep 'em.
Old Feb 4, 2015 | 05:04 PM
Simpleaim's Avatar
Thank you but how would I know what within tolerance is? I should note that this is my work vehicle but I'm taking a week off to do this job and all of my parts come from Rock Auto. Once I get it apart I don't want to wait for parts to get in. Would these normally wear out after 200K miles?
Thank you,
Old Feb 4, 2015 | 05:32 PM
MGDfan's Avatar
Hey.
Yer just one follower away from this:
https://www.f150online.com/forums/v8...4l-3v-problems.
I'd change 'em.
Also - don't use Dorman valvetrain components - Motorcraft only:
Lastly - don't fergit the new latest-rev VCT solenoids & seals ( and don't fergit to inspect & clean the VCT solenoid bodies ), new tensioners and guides, remove/inspect/clean sludge off the two CPS's, etc, etc.
Good luck!
Old Feb 4, 2015 | 07:45 PM
Simpleaim's Avatar
Wow!! Thanks for the advice. That's what I needed to know. What's CPS?
Thanks,
Ken
Old Feb 4, 2015 | 08:26 PM
MGDfan's Avatar
Thanks,
Ken
Howdy.
CPS - Camshaft Position Sensors. There are two - on fer each bank - mounted just below the valve covers. They can get kinda spoogy.
https://www.f150online.com/forums/20...ml#post5127392
BTW - VCT solenoid & seal info/part #'s: https://www.f150online.com/forums/20...ml#post5126421
good luck
MGD
Old Feb 5, 2015 | 09:02 AM
Simpleaim's Avatar
Nice. Thank you MGD!
Ken
