Front Lower Ball Joint Recommedations
Recommendations for a grease gun? Lol. Whichever one works. I've had $20 units that don't leak and I still have. I've had $50 units that leak and failed in a year or two. Just buy a walmart/harbor freight gun and have at it. Just make sure to use it sparingly, like 1-2 pumps of grease. I do recommend the trigger-style pumps for one hand operation, used with a flexible hose in order to get in the tighter spots.
Hello 2008_XL,
Thanks for the explanation. Now I understand the benefit of installing a non-sealable ball joint. Regarding the Ford OEM ball joint, I was able to get approximately 135K miles out of them before they went bad. My truck, too, is stock and has never really been off road. She is more of a commuting truck. I actually love driving my truck more than my other cars.
Also, I like to do as much maintenance and repair work as I possibly can (thanks YouTube). I change my oil, rotate my tires, etc., etc.; however, I am a little worried about greasing the Moog ball joints. Is it really that easy to grease those joints? How do you ensure that you don't over grease the joints?
Thanks again for the information.
Donald
Donald
I've had the Moog upper bjs for a couple years and have done this. The boot it still intact. You will see old grease dripping down the control arm. This is normal. When you add new grease each time, it forces the spent grease out of the bottom.
I have several fittings on several vehicles that do require greasing and I've been doing my own maintenance since I was a lad, 45 years anyway ..... and some where along the way I learned to use a grease gun that I can operate with one hand while feeling the boot with the other if possible and stopping when I feel a slight swelling and before grease comes out of every crevice.
When greasing my driveshaft slip joints or my Wheel Horse's deck wheels and bearings for blade shafts, etc, I pump till I see grease.
You're welcome. If you like doing maintanence, you should go with Moog. Greasing is simple. They usually come only slightly filled and you'll need to add some. Feel the rubber boot when you're adding grease. It should feel slightly plump. After that, just use two squirts from a grease gun about every 3000-5000 miles (every oil change) and you'll be set. No need to add more or less. They will not break the boot with that amount and interval.
MGD
Thanks,
Donald
Thanks,
Donald
"Lastly, I will ensure that the parts are Ford OEM parts and not cheap Chinese parts."
I've been disappointed when reading "made in" labels, regardless of the "brand" name on a package. I do like greasable fittings though.
