Smelling gas in my 08' mark LT
Old Nov 1, 2014 | 10:57 AM
philip 87's Avatar
Hello,
I apologize if this topic has been addressed already.
Last week while driving to the store I heard a sound that sounded like I had been driving on a flat tire.......flop flop flop flop flop.
I pulled over and tires were fine.
Getting back in truck and drove away fine with sound gone BUT.....
I started smelling gas in the cabin. Its been there ever since.
Its faint but clearly gasoline smell still.
Any idea's?
Thanks in advance guy's.
......Philip
Old Nov 1, 2014 | 10:59 AM
philip 87's Avatar
PS
I dont see any gas under car on floor where I park each night.
I looked under hood but to my eye, I dont see or smell any gas.
Old Nov 1, 2014 | 11:20 AM
MGDfan's Avatar
Check to see if any of yer sparkplugs have loosened. Uncommon, but has happened to folks. It can result in that smell.
good luck
MGD
Old Nov 1, 2014 | 11:24 AM
SFM's Avatar
SFM
+1 on the loose plug. Had the same thing after a plug change.
Old Nov 1, 2014 | 02:03 PM
JackandJanet's Avatar
Personally, I'd suspect a saturated Evaporative Emissions Control canister. If you regularly "top off" the fuel tank when you fill up with gas, I think you can cause it to do this, but it should clear if you stop topping off.
Otherwise, the system may have to be replaced.
- Jack
Old Nov 2, 2014 | 02:39 PM
philip 87's Avatar
I am bringing truck in to dealer in morning. Hope they find a simple fix.
Thamks guys
Old Nov 2, 2014 | 10:31 PM
08FX4SC's Avatar
Fuel injector
Old Nov 3, 2014 | 09:57 AM
philip 87's Avatar
- Jack
Just back from dealer with my truck.
You were right! and thank you.
Old Nov 3, 2014 | 10:03 AM
You're most welcome! Thanks for bringing this issue to closure.
- Jack
Old Nov 3, 2014 | 05:00 PM
slo5oh's Avatar
- Jack
Someone told me when I was ~16 that topping off is bad, but this is the first I've heard of this. Thank you.
Old Nov 3, 2014 | 05:14 PM
MGDfan's Avatar
It's been a bad idea since gas tanks were invented.
Gas expands with heat - needs somewhere to go. With the advent of evap control systems, it goes into the vapour collection tube and eventually saturates the media in the canister.
Still - nine times outtta ten at the Costco pumps, folks is madly a-clickin' away, squeezin' in that last microliter of gas. Despite all the signs posted saying not to. Sad, that.
Nice catch, Sir Jack.
BSB
Old Nov 10, 2014 | 04:23 PM
philip 87's Avatar
Well a week later, the gas smell is back.
Went back to dealer and they can't figure it out.
You can smell raw gasoline faintly under hood and big time in the cabin.
Old Nov 10, 2014 | 04:34 PM
MGDfan's Avatar
Did they check the other possible causes listed in this thread? A loose plug is going to involve some actual work on their part to inspect, as are loose injectors, faulty o-rings, fuel rail fittings, fuel filter fittings, etc ... even the PCV system ...
good luck
MGD
Old Nov 10, 2014 | 05:52 PM
So much for my "nice catch"...
Wonder if they didn't hook something up right when they serviced the evap system? It doesn't take much gas to create a strong gasoline smell.
- Jack
Old Nov 10, 2014 | 06:00 PM
MGDfan's Avatar
- Jack
Roger that, Sir Jack.
It IS a complex system, after all.
OP - best of luck!
Regards;
MGD
