show them trucks off!!
Stunning! Still one of best trucks I've seen. You have just the right amount of chrome on your truck! Are those Mark LT door handles and tailgate handle? If so, is the swap easy to do?
), but otherwise it's easy. Sanding textured handles smooth in prep for paint takes 10 times more than painting or re-installing handles.
Those handles are actually my original ones. My truck was a Lariat Chrome package truck, came with textured handles but chrome pulls. I just sanded them smooth and had them painted, masked my handles off. The job of the swap itself isn't bad as Kmac said, it is tedious, but manageable. Some patience and mildly thin hands work fine with the process.
Just throwing my experience in, taking the door handles on and off isn't bad at all. You do need to be careful with the driver door because of the rod connecting to the lock cylinder (I bent the rod, snapped the clip holder, damage the back of the cylinder, etc
Thanks for the compliment! I feel it is a well balance also. I wanted black out, but with accenting.
I think the Mark LTs look nice on black and white trucks.
It really just depends on how much you value your time. I'm 20, so my time ain't worth a whole lot, and sanding was so much of a PITA that I possibly would get already-smooth ones if I could go back. It also depends on how smooth you want/need them. I wanted them to look as close to factory as possible, with absolutely no texture, so that required 2-3 of sanding for each handle.
