Rattle under the hood. Engine? Transmission?
2004 5.4l 2WD 173000 miles
I have a really noticeable rattle when I let off of the accelerator when driving. Even after light accelerating.
It seems like the same rattle I have at start up. I've had the start up rattle since 89000 miles but it would always go away after a few seconds.
I also have a loss of power when accelerating.
It also makes the noise in park
Any ideas of what it is?
Finally set some timing codes:
P0011
P0021
P0022
P0345
The noise must be the broken plastic guides in the chain path.
Gonna tear into replacing the guides. Also going to remove the oil pan to remove the broken pieces.
P0011
P0021
P0022
P0345
maybe, but the rattle is like plastic rubbing on bicycle spokes.
I haven't really read about phasers going catastrophically bad.
I've only read that mechanics have told owners they were on the verge of it all going south, and that 1500 dollars later they should feel glad they let them do the work.
If I have the phaser noise afterward, then I'll consider doing those at a later date since they can be replaced without tearing down the front.
