2007 F150 lariat 5.4 fuel pressure issues
Old Mar 19, 2014 | 05:07 PM
jessesmall82's Avatar
Truck sputtered, ran enough to get off road, occasionally would run for a few seconds and then quit running last week.........dropped fuel tank and changed fuel pump....(didn't have right size fuel filter so didn't change old one)....ran fine for 30 mins then the same thing as before......it would start up and run for a min or two then died.......changed fuel filter.....truck ran good for 2 days then started acting up on my ride home....never stalled just sputtered.....Plugged in code reader and it said fuel rail pressure sensor out of range......drove fine 2 more days then started sputtering and dying but would always restart.......got home truck wouldn't start......took 1 side of fuel filter off and turned key....nothing for about 2 seconds then fuel flowed normally.....replaced fuel filter again ......next day would not start.....took off 1 side of fuel filter and same thing no fuel Then fuel.......drove it to work and after about 30 miles started sputtering and killing.....but always restarted......drove home same problems but worse.......replaced fuel pressure driver module...went to start truck and nothing....dropped fuel filter and same as before no fuel then fuel......noticed the fuel pump made less the desirable noises when cycling the key after it was primmer.....tried to drive to work and it was finefor 30 miles then stumbled for a min or two and then killed would not restart.........I watch the live data on my reader and fuel pressure drops to 1 or 2 psi when it is having issues.........what's left to drop more money into? Fuel pump bad again????? Give me a direction I'm lost now......thank u
Old Mar 19, 2014 | 05:11 PM
To sum it up....new fuel pump.....3 new fuel filters.....new fuel pressure driver module..... And still not Running.....sorry for incorrect spelling.....I'm at work
Old Mar 19, 2014 | 06:01 PM
Maybe the fuel rail pressure sensor is bad?
Old Mar 19, 2014 | 06:06 PM
I talked to ford about that this morning and they seem to think its not an issue......it would take 4 or 5 days to get the part (they say its not common at all) what about the fuel pressure regulator????
Old Mar 19, 2014 | 06:49 PM
You don't have a regulator, the FPDM controls the fuel pump. It's a variable pressure system, not a return system that does use a regulator.
The rail sensor is 85 bucks at Rock Auto, in stock, if you want to shotgun it.
Old Mar 24, 2014 | 08:39 AM
Ok so I fixed the issue..... Up underneath the driver side door where the wiring harnesses connect, there is a little open top housing to shield the connectors......it was full of mud...frozen/wet.....2 wires were bad.....I snipped and hard wired and the truck runs good now......
Old Aug 23, 2021 | 11:32 AM
Fortega Alex's Avatar
I have the same problem, help me please
I have the same problem, you will have a photo of the place where these wires are or of your repair. Or what signal goes in those wires.
Old Apr 8, 2022 | 06:20 PM
james brady's Avatar
Same problem
Did you manage to figure it out???
