Dome light problem
Old Jan 25, 2014 | 09:59 PM
bnkrupt's Avatar
Dome light problem
So I have a problem with my dome light. It doesn't stay on it randomly turns on by itself. While going down the road my truck will begin to chime as if the door is open, but it isn't. So today I noticed that the dome light was on again. I have checked various fuses with no answer to the problem. Any help would be great, thanks in advance Mike.
Old Jan 25, 2014 | 10:19 PM
gbctrdrman's Avatar
More than likely it's the switch in the door that let's the computer know it's open..
Old Jan 25, 2014 | 10:47 PM
Just curious - why are you checking FUSES? That makes no sense.
Old Jan 25, 2014 | 11:08 PM
bnkrupt's Avatar
The reason I was checking the FUSES, I didn't want to mess with it anymore tonight, and didn't want it to drain my battery. That's why I was trying it find the fuse. But when I pulled the fuse for f24 the dome light stayed on.
Old Jan 26, 2014 | 12:54 AM
Sorry, it sounded like you were thinking a blown fuse would CAUSE this issue. My apologies.
Old Jan 26, 2014 | 04:54 PM
bnkrupt's Avatar
The mods can delete this post. I found the problem to be the door jamb switch located inside the door.
Old Jan 26, 2014 | 05:52 PM
Why should they delete it? It needs to stay so others can learn from it. That's what a forum is all about.
Old Jan 26, 2014 | 06:28 PM
MGDfan's Avatar
For refernce - -discussed in detail here: https://www.f150online.com/forums/el...ying-read.html
This is a Sticky in the Electrical Section - which apparently no one reads, lol.
MGD
Old Jan 26, 2014 | 06:30 PM
MGDfan's Avatar
Ahhh ..... I've named that "The Pockets Effect"
MGD
