Rev limiter
Old Sep 12, 2013 | 05:29 PM
Hunter1660's Avatar
Rev limiter
Thx
Old Sep 12, 2013 | 06:33 PM
kingfish51's Avatar
I don't think your problem is a rev limiter. That should be at minimum 5k. Start looking for other problems. Definitely check to see if there are any codes.
Old Sep 12, 2013 | 06:39 PM
Originally Posted by Hunter1660
My 2005 expedition will not rev past 2750 rpm in park...it does the same thing going down the road...stumbles..shakes...engine light flashes..cycle the key..the light goes off...starts and runs perfect.....it'll cruse smooth as silk as long as you don't try to push it past the 2750 rpm...like passing another vehicle....the rev limiter is kicking in at 2750 rpm???...any thoughts?..anyone seen this before... Cure???
Miles? Have the plugs and COPS been changed?
Its not your rev limiter
Old Sep 12, 2013 | 07:17 PM
Hunter1660's Avatar
Thx
Old Sep 12, 2013 | 09:11 PM
If this were a F-150, I'd say to check the FPDM for corrosion and replace if needed.
It could be the rev limiting function kicking in too early - due to a faulty PCM or corrupted programming - or a problem with a sensor or wiring somewhere.
