Help!!!!!!!
Old Aug 2, 2013 | 09:13 AM
thomabro's Avatar
Help!!!!!!!
I have a 2006 screw f150. driving to work today and about 10 blocks from the house the radio turned off... then the a/c.. then the gauges... then the locks and windows stopped... then my php programer shut off... then my blinkers and lights, by the time i pulled in to the parking lot at work my motor was barely running. now it wont even try to turn over. It did rain yesterday but i didn't go through any puddles out of the ordinary so I don't think it would have gotten wet. But regardless, now I'm stuck at work and have no vehicle.
Old Aug 2, 2013 | 09:27 AM
Have you had the battery checked? Sounds as if it has died.
Old Aug 2, 2013 | 09:44 AM
DewserB's Avatar
TRUCK OF THE YEAR 2013
^ This. It sounds like the battery may have died because the alternator also died. Maybe? I'd get them both checked.
Old Aug 2, 2013 | 10:01 AM
thomabro's Avatar
I checked the connections, they appeared fine. The battery itself is about 3 years old. It just scared me a little how everything died in a cascading affect going down the highway. Thanks for the suggestion though guys. Ill stick the charger on it and see if I can get a light or anything to come on, and if so ill go buy a new battery at lunch and check the alternator. luckily the truck got me to work, instead of leaving me on the side of the road.
Old Aug 2, 2013 | 10:25 AM
DISCONNECT the programmer till you get this sorted out!
Old Aug 2, 2013 | 10:44 AM
thomabro's Avatar
Im glad you reminded me glc, I was worried about the rest of it and almost forgot.
Old Aug 2, 2013 | 03:31 PM
thomabro's Avatar
Ran by autozone on my lunch break to have the battery and alt. checked. They said they could not get the battery to take a full charge, as well as with the truck running the alt. was only putting out 12 volts. so I don't know if its which one is causing the problem, if not both. In the event I need a new battery, what is a good one to go with now days? I do have off road lights and stereo amps to run so I'll need one that can handle that.
Old Aug 2, 2013 | 10:24 PM
Sounds like you need both.
DieHard Platinum. Open your wallet wide.
Old Aug 3, 2013 | 08:58 AM
mkinttrim's Avatar
Interstate makes a damn good battery
Old Aug 3, 2013 | 09:23 AM
gcart's Avatar
^^^ this.
Old Aug 3, 2013 | 09:58 AM
thomabro's Avatar
I currently have a DieHard Platinum. checked the paper work last night and I still have 20 days left on the warranty. So worse case scenario, I need to buy a new alt. Thanks for the help guys.
Old Aug 3, 2013 | 11:05 AM
The Platinum is an AGM battery and can be difficult to fully charge with a conventional charger. Take it over to Sears and have them check it out.
Old Aug 3, 2013 | 05:22 PM
thomabro's Avatar
I did take it to sears and they fully charged it and said it was good. I then put it back in the truck and put a multi-meter on the alt. it read 13.5 volts with the motor idling and no electronics on. But as soon the A/C or similar was turned on the reading dropped to the low 12's. I went a head and ordered a new alt but it wont be in until Tuesday.... so I guess ill just keep driving my new 6.7 power stroke work truck until mine is fixed lol. hopefully the alt fixes it.
Old Aug 3, 2013 | 07:24 PM
rednoved's Avatar
Did it go back to 13.5 when you cut the AC off?
Old Aug 3, 2013 | 09:59 PM
miseroth's Avatar
Sounds similar to what happened to my wife's 2003 Expedition - ending up being the IAC valve. Just making sure you consider all possible issues.
