How do I switch/move the pins around on a harness
Old Apr 26, 2013 | 06:32 PM
nuclearthreat54's Avatar
Exclamation How do I switch/move the pins around on a harness
For my tow mirrors. I have a 2006 lariat with power heated turnsignal mirrors that im switching out for power heated signal and puddle light 2007+ tow mirrors. I searched and Im kind of a noob at this, I thought it would be easier but the pin seems fragile. Also I know which pins on my truck do what but I cant see to find a diagram for what the pins on the mirrors are for
https://www.f150online.com/forums/20...inally-17.html
I used that info but im not sure, the pin wont seem to release...and I also still need to find the correct info on where to move the pins to. I can only find the harness info for my truck.
Edit: Ok I got the pin out and switched it, and then cut off the 2nd ground. I plugged it in and the movement works but I dont have turn signals....Any ideas? Im still trying to find the proper wire diagram to put all of the questions to rest of where and what wires do exactly what.
TO SUM EVERYTHING UP!!! The driver side tow mirror pins were bent and each time I would plug them in one would miss and wouldnt allow the turn signal to gain power. Everything is connect and works fine now thanks.
TL;DR 2006 POWER, SIGNAL, HEAT Lariat MOVE PIN 9 to 8 and cut PIN 2.
