Intake Pulling Trash
Old Apr 17, 2013 | 07:24 PM
lakemarykid's Avatar
Does anyone else's intake pull a lot of leaves and pine needles in to the air box? Is this due to the GOTTs mod? Every time I clean the filter, there is a bunch of trash in there. Any one else experience this?
-Curtis-
Old Apr 17, 2013 | 08:01 PM
A ton of leaves will get pulled into the space inbetween the inner fender skin and the engine compartment wall. You're pulling them in because your gotts mod PVC is not going far enough into the wall. The stock intake goes past the compartment wall, then past the inner fender wall; so it sits in between the inner and outer fender, where there are no leaves. Your PVC is ending between the compartment wall and the inner fender, where all the leaves are.
Old Apr 18, 2013 | 09:24 PM
fine_style150's Avatar
What Kmac said. I used spectre tubing so I was able to keep the rubber coupler it comes with to hold in place at the fender and extend the tubing material the necessary to match the oem snout
Old Apr 18, 2013 | 09:49 PM
Ross-FX4's Avatar
Seen a little in there.
Have to check for snow during the winter months.
Roush CAI Box.
