Is this even safe??
Old Apr 1, 2013 | 06:15 PM
BuRDeN04FX4's Avatar
Is this even safe??
Easy question is this safe 5.5 pro comp blocks stacked on top of stock blocks
It should only be for 2 or 3 months till I can get some custom springs made
I cant upload a pic right now ill try again tho
Old Apr 1, 2013 | 07:18 PM
Another question is only 2 5/8" inches of the drive shaft sticking into the end of the transfer case safe? Probably not huh guess im gonna have to bring it somewhere and get the drive shaft lenghtend from my measurements it need to be another 2 5/8" longer.
Any thoughts on any of this?
Old Apr 1, 2013 | 07:43 PM
tbear853's Avatar
... etc ...
Not on my truck, no way!
transfer case safe?
... etc ...
I'ld want more in mine, 2-5/8" is gonna amplify any clearance between splines and let the yoke wobble and
swing the shaft more like a jump rope which will destroy rear tailshaft bushing and seal and at speed, can lead to
'rude events'.
Love the Flaresides.
Old Apr 2, 2013 | 04:42 PM
Lifted5.4Lariat's Avatar
NO 5.5" blocks by themselves are scary as it is. Add a lift shackle, or run it with the rear sagging until you can get new leafs would be my advice. That's just asking for trouble.
Old Apr 2, 2013 | 05:05 PM
Just lower it and be done
But seriously, I'd pass on stacking 2+5 as well
Old Apr 2, 2013 | 05:16 PM
beechkid's Avatar
25 Year Member
No..................
Old Apr 2, 2013 | 05:35 PM
Thanks for the advise the trucks just been sitting in the driveway since I installed the blocks I was a little nervous so wanted to get some advice. Thanks for the info everyone. I guess i have to take them out even tho the truck does sit perfect how it is now. 47" from ground to top of fender. I guess ill just have to drop the front for a bit
Thanks again everyone
Old Apr 2, 2013 | 09:55 PM
tbear853's Avatar
Yeah .... it won't hurt a bit!
Old Apr 2, 2013 | 10:09 PM
Lowering the front seems like a bit overkill, especially if you have already had the truck aligned. Lift shackles can get you 1.5" I believe. What is 1 inch lower in the rear going to hurt as far as being temporary?
Old Apr 4, 2013 | 09:38 PM
StoveTop's Avatar
Look into getting the Fabtech driveshaft spacer...the cheapest insurance you're going to find for your truck after lifting. Was about a 25min install.
Fabtech Driveline Spacer Link
