2007 f150 fan clutch removal?
trying to figure out how to remove the fan clutch on my 4.6.... i took the 4 screws off of the water pump pulley... except that i'm being told to hit it with a hammer to release it. not enough space for it..... i am going crazy looking for videos on this but nothing pops up..... if any has been through this please help me
Or get a large breaker bar or a long rock chisel and a mini sledge and tap/hammer on it till it pops off. Same principle as the air hammer, but manual.
Don't pry on it though... you might bend or break something.
Another way is if you got a SDS handy with chisel only mode (rotation stop) with a long chisel... if you can fit that in there, that would also work.
think i overheated my engine. the top, where the intake is at is making a hissing noise. so now not only my clutch, but i believe head gasket. its going to be well over two grand to fix now. correct me if i might be wrong. i hate this bad news. i still owe 4800 on it. i got fired from the last four jobs i have had. i am looking for a new job. it has came down to car salesman and a security officer. bad truck means not being able to go to work if and when i get called to perform.
Might be a little late for this, but, the large nut (1 1/2" + -)must be removed from the nose of the pump before the pulley can be removed. Local parts stores may have the tools you can rent for this purpose. Using hammers or breaker bars are only going to cause more damage for you.
