Replaced fuel drive module, now truck won't start!
Old Mar 21, 2013 | 08:39 PM
Palladogs's Avatar
Hey guys, I've got a 2006 f150, 5.4 v8, I was having problems with the truck, I forget what code came up on the edge. But after some research I came to the conclusion that it was possibly the module, went ahead and replaced it today and now the truck won't start. My headlights flash on and off when I try to start it, and the edge flashes, but the truck won't turnover.
Any ideas?
Old Mar 21, 2013 | 10:18 PM
tbear853's Avatar
Did it start before the swap? If so I'ld swap back and check.
Old Mar 21, 2013 | 10:57 PM
Palladogs's Avatar
Yep the truck did start Before the replacement, I tried the "old" one back and I had the same result. I did notice the instrument cluster gauges were almost vibrating back and forth quite fast as u removed the key from the ignition.
Old Mar 21, 2013 | 11:16 PM
Check your battery
Old Mar 21, 2013 | 11:40 PM
Yep. Battery
Old Mar 22, 2013 | 12:03 PM
tbear853's Avatar
Sounds like when my '07's group 59 battery died suddenly last year, swapped in new Kirkland Group 65 .....
Old Mar 22, 2013 | 12:51 PM
mkosu04's Avatar
The fact that it won't turn over tells me that its not the FPDM...
If there was a problem with the FPDM then it would crank but not get any gas so it would never fire. (right?)
Old Mar 22, 2013 | 12:52 PM
check the battery....
Old Mar 23, 2013 | 08:05 PM
Palladogs's Avatar
Replaced the battery and she fired right up. Everything seems to be in working condition.
Appreciate the help guys.
Old Mar 23, 2013 | 08:35 PM
good....glad ya got it fixed....
