Bad electric connector on chassis
Old Mar 16, 2013 | 06:05 PM
shovelheadrob's Avatar
I've done a search but can't find an answer. I have an 07 F150 Harley, there is an electrical connector on the chassis below the drivers footwell, it has a plastic shroud to protect it but it still gets filled with water spray. It is showing signs of corrosion & has caused the gas gauge to read incorrectly & today the ABS light has come on which I believe is due to a bad connection in the same connector, has anyone else had a problem with this & what is the best solution? I'm guessing that replacing the connector will get things working again but I don't know where to source one from (I'm in the UK) it really needs better protection from the elements, any suggestions?
Old Mar 16, 2013 | 09:36 PM
Have you tried unplugging it and cleaning it?
Old Mar 17, 2013 | 12:18 PM
Yes I have unplugged it & cleaned it with contact spray, but the pins are very small dia, if I could source the correct pins I would replace them as the connections are still bad.
Old Mar 17, 2013 | 02:06 PM
tbear853's Avatar
Pack it with some dielectric grease when finished.
It'll help seal the connectors and the metal contacts without inhibiting electron flow ..... "dielectric".
Old Mar 18, 2013 | 04:37 PM
thisguyuknow's Avatar
how many pins are in the connector? Do you have a pic of the location? I find it odd that it is affecting to completely different electrical systems.
Old Mar 27, 2013 | 04:07 PM
Here is a photo of the location, I should add that there are actually 2 multi connectors, there are around 20 pins in each connector & I believe that they should both be replaced as there are signs of corrosion in both.
Viewed from below the drivers door, you can just see the transmission crossmember
When I first had a problem with the gas guage & also the rear parking sensors last year I found that the cover was competely full of dirt as it collects everything that comes up from the front wheel. I cleand it all out, drained the water from the connectors & sprayed them with contact cleaner, everything worked fine for 6 months, but recently we have had some pretty bad weather here & now I've got problems again.
Old Mar 28, 2013 | 05:13 AM
code58's Avatar
Holy mackerel, they sure put those in a bad place didn't they? Even covered they get a lot of crap in there. I'm quite sure my '04 doesn't have anything like that, but I know they changed a LOT of the electrical in the '07 because my SIL has one and it's a lot different than my '04 though the truck looks the same.
Old Mar 28, 2013 | 03:04 PM
Caterpillar3516's Avatar
I had the same problem with my 06 Larait. I ended up cutting both connectors off and replaced them with Deutch connectors. They are gold plated pins and a weather tight connector. The only problem is they require a special crimp tool, and its not cheap......I happened to have one on my service truck.
Old Mar 30, 2013 | 07:22 PM
maxpat82's Avatar
No issue with my 07 with 60K miles.
I live in montreal, canada.
Even with all the bad stuff and rustproofing stuff..everything work fine.
Unplugged it a couple week ago to replace fuel filter and everything wasnice in the connector.
