Fog Lights
Old Mar 7, 2013 | 01:37 PM
DaWG of Indpls's Avatar
Fog Lights
Guys, I have factory fog lights on my 2007 Lariat. I recently upgraded the bulbs to 65 watt bulbs. Am I in danger of overheating the wiring that feeds those lights? The bulbs that were in there were 45 watt bulbs. I run my fog lights at all times when my headlights are on.
Any thoughts?
Old Mar 7, 2013 | 02:11 PM
SoonerTruck's Avatar
You don't run any danger of overheating the wiring, but melting the plastic lens is a definite possibility.
Old Mar 7, 2013 | 04:20 PM
Thank you. That is a consideration I had not thought of. I actually thought those lenses were glass. Thanks for the heads up.
Old Mar 7, 2013 | 04:55 PM
tap on them with your knuckle, you'll see they're polycarbonate.
Old Mar 7, 2013 | 07:13 PM
Any thoughts?
This......
Melted lens....45 watts is the highest I'd go in the round fog lights....
Old Mar 7, 2013 | 07:22 PM
Big's Avatar
Big
Yeah, I've never had good luck with upping the wattage on bulbs. After several bulb plug melts over several vehicles, I got the hint. I believe there are bulbs that are brighter while keeping the wattage the same, but I've given up and haven't researched it.
Old Mar 8, 2013 | 06:53 PM
35w HIDs add brightness and lower wattage.
