clunk in drivers side front should I replace hub ??
had another topic going about this, anyhow backed out of driveway this morning & turned into street & front tried to enagage driverside pass side accuklator has been done , should I replace hub while Im that far or just inspect, cause it has 165,000 miles on the truck, need to do this saterday morning & need to know what parts to get??? On the drive home I got close to home & put it in 2 wheel dr, & it didnt clunk but that was a mile ?? Thanks for all input...
mine made clunking noise in 2WD but was quiet in 4WD High. Fairly easy fix. I bought the hub actuator and the solenoid that mounts behind the battery. I would just buy the hub. I don't think my solenoid was bad. I took about an hour to rpelace with a lift and impact wrench and i knew what i was doing to some extent.
Ford OEM Part# 7L1zc3247a $124.47
