5.4L Spark Plug removal with an impact
Old Jan 22, 2013 | 09:00 PM
costellokg's Avatar
Has anyone tried this? Especially since its the opposite of Ford's TSB 08-7-6.
I just don't know if I have the ***** to use an impact wrench on a spark plug, but he makes it look easy.
That's the best method...
Old Jan 22, 2013 | 11:40 PM
powerz69's Avatar
I wonder how many PSI he was running at? I also thought you weren't suppose to put anti seize on the threads?
Old Jan 23, 2013 | 03:19 AM
code58's Avatar
Not on the threads but on the ground barrel. Nickel anti-seize. The jarring of the impact causes less chance of breakage than the twisting with a socket wrench.
Old Jan 24, 2013 | 09:48 PM
Caterpillar3516's Avatar
I saw the same video and tried it out. I started with a 12volt Milwakee 3/8 drive impact. It had no effect.....truck had 82000 miles on original plugs. I switched over to a Matco 3/8 drive air impact and was able to get 7 of the 8 out. One of my back plugs broke but it appeared that it may have been broken for a while (truck would miss under heavy load). I did bring the engine up to temp and sprayed PB-Blaster down the plugs. Some came right out some took a foward/reverse sequence before they came. Use this method with caution but it does seem to work best. I would still have the extraction tools on hand.......just in case.
Old Jan 24, 2013 | 10:32 PM
If I'm not mistaken, an actual Ford tech who hangs out around this site (Quinton?) swears by this method.
Old Jan 24, 2013 | 10:48 PM
flamed20's Avatar
our senior master tech uses his 3/8" impact on everyone he does and he rarely has one to break on him..
Old Jan 24, 2013 | 11:44 PM
I've done to many to count with an impact....especially the 3v's with the heat shield snout.....now on the 2v's I still use hand tools.....
Old Jan 25, 2013 | 09:51 AM
https://www.f150online.com/forums/v8...ess-8-8-a.html
