05' Rear road noise??
Old Jan 8, 2013 | 09:16 PM
yngfireman's Avatar
I have a 2005 fx4 and I have some type of "road" noise coming from the rear end. I don't know if it's the tires or what. I had the diff. fluid changed and fricton mod. added. The "road" noise is still there. Any ideas? Should I see if they can add more fricton mod.? I don't think there is any other issues that go along with this noise. It seems louder in the back seat than the front. Thank you for any help in advance. My kids are driving me crazy about hearing this noise.... Haha
Old Jan 12, 2013 | 07:25 PM
yngfireman's Avatar
Old Jan 17, 2013 | 06:40 PM
yngfireman's Avatar
Could it be the tires???
Old Jan 27, 2013 | 03:43 PM
yngfireman's Avatar
Anyone???
Old Jan 27, 2013 | 05:39 PM
wheelerfreak's Avatar
I think "Road Noise" is pretty vague, that may be what is holding people back? Road noise is generally associated with tires on the pavement. Gear whine, vibrations, etc could be drivetrain related. It's really hard to say with such a vague description.
Old Jan 27, 2013 | 05:42 PM
2stroked's Avatar
First, "road noise" is a pretty broad category. Second, it's virtually impossible to diagnose any noise over the internet. Yes, tires can generate lots of road noise. So can a bad wheel bearing, bearings going bad within the differential, a cat stuck in the driveshaft and any number of other things. If you want us to be any help at all, you're going to have to get more specific.
Old Jan 27, 2013 | 07:04 PM
yngfireman's Avatar
OK, sorry about that. I really don't know the difference in the noises. It doesn't sound like gears grinding. When I turn I don't hear anything different as far as clicking or banging. When going down the road its sounds like I have super swampers on my truck on the rear. Which is why I think it's the tires, but the tires are the same tires on the truck for a while and I just started hearing the noise. When the diff oil was changed the dealership said the gears looked OK.
Old Jan 27, 2013 | 07:13 PM
aussiekeeper's Avatar
The vents in the rear of the cab wall will open when driving and will magnify the sounds coming from the rear of the truck..........
Old Jan 28, 2013 | 06:32 PM
yngfireman's Avatar
Aussie.... on my truck the rear seat,the bottom lifts up but the back doesn't move. Do I need to take it out to get to the vents?
Old Jan 28, 2013 | 08:31 PM
Is it a Crew Cab? If so, there are Releases on the back top of the seat at each side. I used a screwdriver to get to them, they are kind if a biotch to get to. Pull the back cushion forward and you can see them. I would not cover both of them, the vents, they are used to equalize the cabin pressure when the doors are closed and to release air when the heater or a/c is on. You can cover one of them. Also, I used a Dynamat like product on the back wall metal, it helped a lot.
