Front Rotors replacement
Old Oct 15, 2012 | 10:52 PM
1931Chevy's Avatar
Well guys the time has come to replace my warped rotors of my 04 Lariat 4X2, I want to know if I should go with OEM rotors or replacements from AAP Pep or Autozone, Which option would you recommend me, I want my rotors to have US bearings and no cheap chinese bearings so what options are out there
Old Oct 15, 2012 | 11:43 PM
602F150's Avatar
I replaced mine about 5,000 miles ago with Motorcraft and they are great.
Old Oct 16, 2012 | 12:00 AM
animated_zombie's Avatar
I have Powerslot slotted rotors on mine. I will worn you though, if you end up going down that road, you have to order the Centric hub as well. The 4x2 factory rotors have the hub included, so if you want to go with aftermarket rotors you'll need the hub as well. I'm sorry I know that I'm not describing this very well, so here's some pictures:
DSC03516.jpg?t=1271915267
DSC03536.jpg?t=1271914808
DSC03544.jpg?t=1271914684
Old Oct 16, 2012 | 04:26 PM
dbhost's Avatar
I haven't looked in years, are the 4x4 rotors the same way? I thought the rotors just floated on the hubs / wheel studs like you show on the 4x2 config above... (I did my last brake job 6 years ago...)
Old Oct 16, 2012 | 05:17 PM
SoonerTruck's Avatar
Get the Centric conversion kit. It includes new rotors, spindle nylon locknut, and hubs w/bearings. The 2WD F-150 uses a one-piece rotor/hub from Ford, the Centric (they make PowerSlot) kit converts it to the 4WD-style so that in the future you only have to replace the rotors instead of the hub AND rotor. I have it, the parts are top-notch, and installation is easy as pie.
Old Oct 16, 2012 | 05:19 PM
slo5oh's Avatar
The 4x4 and 4x2's are different. The 4x2 uses a single piece rotor and hub with pressed in bearing. There is a kit sold by centric that converts it to use standard 4x4 rotors. I believe that's the hub from centric above in Animated Zombie's pics.
Here's one of the threads on the kit:
link
Old Oct 16, 2012 | 05:53 PM
Conversion hubs is the way to go if you plan on keeping the truck past this brake job
Old Oct 17, 2012 | 11:16 PM
1931Chevy's Avatar
where can I check some of this kits thanks
Old Oct 18, 2012 | 09:10 AM
I bought mine from RockAuto.
Old Oct 19, 2012 | 01:02 AM
I got mine from Tirerack
Old Oct 19, 2012 | 11:11 PM
0micd00's Avatar
yea conversion hubs are the way to go if ur gonna keep the truck, i got mine on ebay. im really bad with the pics sorry
