keypad
Old Oct 9, 2012 | 04:21 PM
jb07201's Avatar
keypad
im trying to fix my keyless keypad. it doesnt work. theres no power. i pressed all the buttons and nothing happened. what are some steps i can take to try to fix it.
1. I took the door apart and checked the plugs looks fine.
Old Oct 10, 2012 | 04:37 AM
I'd start checking fuses. Your owner's manual will list what each fuse is for. If you don't have the manual you can download it.
Old Oct 10, 2012 | 04:57 AM
If it isn't a fuse, pull the back seat and verify with a volt meter that you are getting power to the keyless entry unit on the rear wall.
Old Oct 15, 2012 | 08:59 AM
jb07201's Avatar
so i had taken the back seat off to get my code and noticed this black wire is cut. any ideas what the wire is for? and which wire or plug am i checking for power?
Old Oct 16, 2012 | 04:42 AM
code58's Avatar
That looks like the ground wire. If you had a Power Probe you could tell if it is a ground wire or not. If it's just cut, twist it together and see if they work.
Old Oct 26, 2012 | 10:58 AM
jb07201's Avatar
Someone should take a picture of there keyless remote module, so I can see how this is suppose to look. (Make sure u cover ur code). Thanks. I'm getting ready to take to dealer. If I can't fix in 2 weeks.
Old Dec 28, 2012 | 10:52 PM
Turd Furguson's Avatar
I will have to check mine out tomorrow. It has never worked. Ugh I am going to have to remove 2 baby seats to do this, but I am afraid my wife is gonna lose the key.
Old Dec 31, 2012 | 08:15 AM
jb07201's Avatar
K. Thanks. Better being safe than sorry
