Need some help on tranny linkage on v6 with body lift
Old Jul 7, 2012 | 10:15 PM
jam92102's Avatar
Ladies and Gentleman,
I desperately need your help. I did a body lift on my 07 f150 v6. Problem is they don't make a lift for a v6. Everything worked perfect except for the transmission linkage.
The dial is off on the dash which is no big deal. When you're in drive the indicator is in between the N and D. When you put it in park the key comes out like you're in park but the truck will roll with a slight ticking. I'm thinking it's just not able to get the truck in park.
I need some creative ideas on how to get the bracket as close to stock (only moved up 3 inches) or if it's possible to adjust the cable to work right. Right now I have to use parking brake every time and start in neutral.
First I'll show you the original bracket that I bought another of.
In this photo I show where the original stud mates up to the transmission.
Is this part adjustable?
Here is where it ends. Don't know if there's anything can be done here.
Thanks in advance,
Old Jul 14, 2012 | 05:48 PM
07Redmonster's Avatar
Yea I had the same problem!! I had to cut the stock bracket and weld that one on had to do some modding but I got it to work. Also took me 30 min to figure out what hear I had it if after I installed this piece cause it somehow it shifted out of park
