Creative Fix to rust near the fuel door.
We've all had a spot of rust here and there, some much larger then others. But coming from the salty roads of Chicago, to the even saltier roads of Guam, there comes a time when you must either,
1. Shell out and have the whole panel painted.
2. Cover it up as best you can with a crappy sticker or fake chrome fuel door cap.
or
3. Make the best of it and end up making something cool.
Here is a before pic.
Note: You cannot see the rust spot as the resolution is low, but it is right below the gas cap about 1/2" down.
Note 2: There are now much bigger tires with the same rims now.
Here is the after mock up I made with Illustrator.
Note: The stripes will be masked off, sanded, primed, and painted with rustolium bed liner (for a rough finish, and a not quite jet black look.)
Note 2: The right thicker stripe will end up covering the rust spot.
Any thoughts or suggestions?
-Mike
or
-Mike
Taping is done, now for the sanding. Priming soon to follow.
Rough sand with 80 grit (orbital sander)
Fine sand missed spots with 220 grit (orbital sander)
Hand sand close to the tape lines, (sander will tear up tape and sand where you don't want)
Two coats of rustoleum automotive primer
Two coats of rustoleum bed liner
Will post more pics soon.
Thank you, I've been searching for patterns of stripes, and I found one example on a mustang, and it seemed very "ford". But putting it on the hood and roof wouldn't solve my problem, neither would putting it near the tail (by the 4x4 decal). I thought about making them vertical, but it just didn't work for me. So, they are what they are.
Looking now ..... it'll look pretty good I think ..... I like the stripes.
Just need to drop the truck lower now!
But really, stripes look good!
Thanks.
As for lowering it, it's not my style, nor is lifting it.
I am making a 2 3/4" leveling kit (I'm a machinist and a welder) for the front to get a perfect level stance and then next tire change going to 35" tires, but other then that, I am a fan of keeping it stock.... to a point.
Thanks.
All finished!! Looks great, solid, and the primer/ paint is holding very well. It has to cure for another 24 hours before going fast (wind might distort the edges above 35 mph) for anyone reading this and trying it them selves. Check out the pics! (I'll post more when its day light here in Guam.)
Thoughts?
Thoughts?
Thoughts?
Thoughts?
