Roaring sound from front end
Old Apr 24, 2012 | 09:27 PM
Fl F150's Avatar
Truck is 2007 F-150 KR 4 x 4 limited slip 3.73 w/towing package.
At around 105K miles I have suddenly developed a roaring sound from the front at low speeds...sounds almost like 35" madders on dry pavement. Tires are stock size Bridgestone Dulers with no weird wear pattern.
It does not grind, pop, click or have any metal on metal sound...just a roar. Does it in 4 or 2 wheel drive.
Any ideas because it seems to be getting worse.
[IMG][/IMG]
Old Apr 25, 2012 | 07:30 AM
wolverine08's Avatar
My guess would be a bearing
Old Apr 25, 2012 | 08:04 AM
nu-supercrew's Avatar
Intake snorkel came loose?
Old Apr 25, 2012 | 09:30 AM
shifty219's Avatar
Clutch fan not working maybe?
Old Apr 25, 2012 | 10:31 AM
malexander52's Avatar
Fan Clutch
When the fan clutch assembly goes on these motors it starts to roar on you. I would start there. It is a loud roar you can hear from inside the cab. Make sure you replace it with the Motorcraft OEM part. The off brand tend to be a little noisy.
Old Apr 25, 2012 | 01:32 PM
Fl F150's Avatar
I could go along with the fan clutch idea except for one thing...if I put it in neutral the pitch or loudness doesn't change.
I'm looking at wheel bearings now.
Old Apr 25, 2012 | 01:59 PM
1997 lariat 4.6's Avatar
x2 on bearings, mine only does it in 4wd, but im not worried about it. HOLY COW Fl 150 you are one of the few originals that still comes to this site!
Old Apr 25, 2012 | 04:39 PM
Fl F150's Avatar
OK...turns out it was the drivers side Bearing Hub Assembly. This is a non serviceable item and must be replaced as a unit. It contains the ABS pick up and everything as a unit.
Old Apr 25, 2012 | 04:45 PM
350-400 bucks too I imagine. What is with the Ford bearings? I have that to look forward too down the line, and have replaced 3 on my '06 Explorer which just turned 60k. I long for the "old days" when you could service bearings as routine maintenance. Probably the reason I opt for extended warranties now, with ea. bearing replacement commanding near 400.00 per replacement.
Old Apr 25, 2012 | 09:17 PM
sam1947's Avatar
RockAuto.com, TIMKIN Wheel hub assy. w/bearings and ABS cable.....$154.00 +- +shipping. Not a hard job to do DIY.
Old May 2, 2012 | 10:01 PM
Dave Rooskie's Avatar
Hold on, guys.
Can't you just press out the old bearings and go on your merry way?
Old May 2, 2012 | 10:45 PM
shifty219's Avatar
Not on a 4x4 truck. The bearings are in a hub assembly that has to be purchased as a whole
