"performance" rotors on ebay?
Old Mar 13, 2012 | 12:39 AM
69ford99's Avatar
Im looking to replace the rotors on my truck with drilled and slotted and have found good deals on ebay for the set of 4. Only thing is does anyone know how long they will last? Usually when you buy something cheap its usually cheap quality.
Old Mar 13, 2012 | 09:21 AM
SoonerTruck's Avatar
Why do you need drilled/rotors? Is this a truck to be used on the race track? 4WD or 2WD?
Old Mar 13, 2012 | 09:28 AM
same answers as here:
https://www.f150online.com/forums/wh...d-slotted.html
Old Mar 13, 2012 | 11:09 AM
c1t1d1's Avatar
Don't waste your money daily driving won't ever get them h it enough and you don't race like what was said above. Factory rotors will do fine just upgrade the pads.
Old Mar 13, 2012 | 11:14 AM
wchamp7's Avatar
i just replaced mine with some i found on ebay that are slotted and drilled that were $227 plus free shipping cheaper than what i could get at an auto store close to me so i got them they are great if there the same set your looking at the i would get them!
Old Mar 13, 2012 | 11:18 AM
Centric has some decent solid rotors that many have used with good results.
Old Mar 13, 2012 | 07:51 PM
Robamus's Avatar
Got em, like em.... I do a fair amount of driving up/down the nearby mountain- about 45 minute trip. Was really taking a toll on my brakes as I kept having warped rotors.
Problem is, on a 2x4, the bearing is still not replaceable (well I guess there is a replacement now). So when that happens, it still SUCKS.
Old Mar 13, 2012 | 11:23 PM
Robamus, there is a conversion kit for the 2wd from Centric. It includes a wheel bearing hub, but allows you to use regular rotors like the 4wd do.
Old Mar 14, 2012 | 10:25 AM
Robamus's Avatar
Hi Sooner,
I saw this but I wasn't clear on if I can replace the bearing in that part or not... Do you know?
Old Mar 14, 2012 | 10:30 AM
Yes, it allows you to convert to 4X4 rotors which have replacable bearings.
Old Mar 14, 2012 | 10:18 PM
PJB4x4's Avatar
I had a set of ebay drilled and slotted rotors on the front of my Mustang and they were ok. I put a good set of pads (Bosch-also from ebay) on it too.
