truck bucks while under load?
Old Jan 21, 2012 | 10:25 PM
hicknick514's Avatar
hey everyone.....so my 04 5.4 f150 has a issue.....i know the tranny might b on its way out but i just wanna make sure that some1 else has the same problem. so while driving up a hill or small incline and accelerating mildly the truck like....shutters or bucks. its a quick buck but will continue in these little bursts. soo tranny.....rear.....? who knows? and i dont think its the motor because that remains constant. no drop in rpm or engine noise
Old Jan 21, 2012 | 11:05 PM
RiverRatF-150's Avatar
Had a similar issue in my '06. Changed Fuel Filter and tranny fluid. Issue is gone now.
Old Jan 21, 2012 | 11:12 PM
ak_cowboy's Avatar
Change your filters and your sparkplugs
Old Jan 22, 2012 | 08:58 AM
spark plugs where just done and the tranny got flushed with synthetic ( which helped the tranny but i was still told to consider a new one) but my fuel filter is probaly due. I'll try that and see what happens. also i just changed that IWE soleniod to avoid any problems with the actuators. (I guess the new ones come with a plastic rain cap haha) but I dont think that could be a issue.....
Old Jan 22, 2012 | 12:24 PM
Peladho's Avatar
I had this issue a while back and I thought it had to be spark plugs and coils but it turned out to be the fuel filter. Anyway its the least expensive to change first
Old Jan 22, 2012 | 09:37 PM
LBT's Avatar
LBT
I had a similar problem and it turned out to be a coil going bad. Never threw an engine code and I would have sworn it was transmission related.
Old Jan 23, 2012 | 12:07 PM
kcward's Avatar
Had similar problem...dealer tore into transmission and found a couple of broken snap rings...but that didnt fix it. They also did tranny fluid flush.
Turned out to be #3 coil. I was very insistent that it was the overdrive.
It had started back up...changed #1 coil seems to have gone away. Worrking on changing all remaining coils since I am at 120K miles...
Old Jan 23, 2012 | 01:16 PM
sampson01's Avatar
kc your problem was only in overdrive around quarter throttle? And if you kicked it down into a lower gear it would go away?
Old Jan 23, 2012 | 06:17 PM
kcward's Avatar
Yuuup!
Around 40-45 mph (1000 to 1300 rpm), would shift into ovrdrive, and give 2-3 jerks...if I was going up a hill, I could make it do it on demand. It was always immediately after it shifted into overdrive...Around 40-45 mph (1000 to 1300 rpm)
If you turn off the overdrive, it wouldn't do it. That is why I thought it was the overdrive...?
Funny thing...I think the coils are crapping out one at a time...replaced#1,2,5. 3 was done back in september. I will probably do the remaining ones next payday...
The truck gave no codes, CELS no nothing! I even bought a scanner/code reader trying to figure this out!
Old Jan 23, 2012 | 06:56 PM
fsulaxer's Avatar
I got a simalar problem, my buddy is a ford mechanic he said to him it felt like torque converter but we are gonna do the plugs and fuel filter once i get the extra money, no check engine lights or codes its like if i am in o/d and give a little throttle not only going up a hill but on flat road to unless it kicks down into a passing gear its almost a guarrentee it will do it
Old Jan 26, 2012 | 04:59 PM
OK04FX4's Avatar
I had the same thing happen. If I turned OD off, bucking would stop. Mine was the #8 coil. Replaced the coil and it fouled up again. Needed new plugs. That took care of it for me!
I would have sworn that it was overdrive going out on my transmission too!
Old Jan 27, 2012 | 03:14 AM
yep mine just did it again. guess i need plugs and coils...
Old Jan 31, 2012 | 10:13 PM
ok so im convinced that its a coil so how can you test to figure which one it is bein thta there are no codes and the truck doesn't shutter all the time ?
Old Jan 31, 2012 | 11:53 PM
Drive it so you force it to misfire and keep misfiring, and it should eventually trip the CEL and store a code.
Old Feb 6, 2012 | 11:49 AM
kcward's Avatar
So in the last week my #8 coil finally went...
As posted above, It started as the jerking when the truck shifted into overdrive. It got progressively worse, but still no codes. I took it for a drive to an area where I could get it to repeatedly jerk, and it finally gave a code for #8 cylinder misfire. Replaced coil with BWD from local auto parts store, and it went away. I've done almost a thousand miles since Wednesday, and it seems good. Also replaced #4 coil. Only 2 more to go til all of the coils are changed out.
BTW...#4 coil is a b#@$c to get to...#8 was easy!
Regards!
