2006 Supercab 5.4 v8 noise issues, Help!!!
Old 12-28-2011, 03:26 PM
Palladogs's Avatar
Replaced the serpentine belt, not sure if the noise is coming from belt tensioner, idler pulley or whatever else, what do you guys think? BTW The truck has 110,000 miles on it. http://www.youtube.com/watch?v=x8-erKkaf0c
Old 12-28-2011, 04:15 PM
risupercrewman's Avatar
Sounds like you need power steering fluid!
Old 12-28-2011, 06:09 PM
BeauFlex's Avatar
sounds like power steering pump to me. have you checked your fluid level?
edit: looks like there is fluid in the resevior. get in and turn the wheel. does the sound change or get worse?
Old 12-28-2011, 06:15 PM
PS pump....
Old 12-28-2011, 07:24 PM
Palladogs's Avatar
Thank for the replies guys,
The sound does not change when i turn the wheel, fluid is ok, and the sound always seems to be there, both when the truck is idleing and driving all speeds.
Old 12-28-2011, 09:49 PM
Mountie's Avatar
I know it might be a no no but did you try spraying anything on the belt to see if it goes away as it sounds the same as a binding belt to me?
Regards,
Peter
Old 02-25-2012, 01:41 PM
FireFighteR6's Avatar
Just wondering if u got this figured out, i am having the same exact sound with my 2005.
Old 02-25-2012, 04:46 PM
Palladogs's Avatar
FireFighteR6,
I did find the problem, i replaced the belt tensioner, the bearing in the belt tensioner was completley shot, id give it a try, i dont think you will have any problems doing the work yourself, Good Luck.
Palladogs
Quick Reply: 2006 Supercab 5.4 v8 noise issues, Help!!!
