How do you take the plastic off the rear bumper?
Old Nov 14, 2011 | 12:45 PM
MossyOak3006's Avatar
Question How do you take the plastic off the rear bumper?
I have a 2006 SLT with the factory chrome rear bumper. I'm wanting to get the rear bumper sprayed with bed liner to match some other stuff that's been sprayed. How do I take the plastic part off the top of the bumper so I can spray up under it. I don't want to tape off the plastic and just spray around it and leave an edge that can peel. So once I get the back bumper off the truck, how does the plastic part come off?
Old Nov 14, 2011 | 04:05 PM
verifine-f-150's Avatar
There are some tabs that are underneath that once you pinch them they pop through the bumper. I got my bumpers line xd this spring and they are still holding strong. The trim pieces are a bit of a pain to get on after they are coated and so is the lock for your spare tire.
Old Nov 14, 2011 | 04:32 PM
So it's kind of like a rivet? pinch it together and pull it out?
Old Nov 14, 2011 | 05:31 PM
fatty4x4's Avatar
On the backside it looks like a plastic V.Pinch the V and it pushes it out. Easy enough. Have patience so you dont break the tabs.
Old Nov 14, 2011 | 06:22 PM
Sounds easy enough. Thanks
Old Nov 15, 2011 | 02:31 AM
tbear853's Avatar
Yeah, but when you put them back .... gonna be tite with the added thickness of the bedliner material. Might use a dremel tool and very carefully with small cut off wheel, cut the plastic back a hair if they won't go down far enough to catch.
Same for the running boards and those pads, though I think they usually break some tyabs coming off from what I read.
Pics when done!
Old Nov 16, 2011 | 10:10 PM
Neggy's Avatar
From my experience, and I have a bit, those pads are "one and done".
They are impossible to get off without damaging the mounting system. I replaced my rear bumper over the summer, and thought I was going to re use mine.
Boy was I wrong.
IIRC a new one is 7L3Z17B807B
$163.60 list, depending on where you get parts you can get from 20 to 40% off that from a Ford dealer
Rear bumper - Bumper and components - Step pad - W/o distance control
Not available aftermarket from Empire or Keystone
W/tow pkg. - Styleside 2004 - 2008
Old Nov 17, 2011 | 10:24 AM
Boy was I wrong.
$163 just for the plastic part?
Old Nov 17, 2011 | 12:02 PM
tbear853's Avatar
Thumbs up
When I purchased our Subaru Forester in 2007, it had damage to the rt frt fender / hood / grille / head light. Estimate was $4400. 55,000 miles, 5 spd, just needed fixing and cleaning. Book was $13-14000. I paid $3500 for it, lady had sold it to a wrecker driver friend because she had cancelled her collision insurance after paying the loan off 2 weeks earlier and could not afford to fix it.
I fixed it for $2300 in parts including new fender, hood, grille, AC Cond & Charge, HL, bumper cover, fender liner, paint for hood and fender, and $90 in plastic push pins of correct sizes and type at Subaru (used all subaru parts). I used a comealong and chain to pull inner fender and radiator support back straight into alignment. There was no frame damage.
In case you missed it, that was $90 in plastic push pins.
Wife loves it, just put a new set of tires on it, 28-32 mpg, good power, and those push pins are still holding here 4+ years later.
Old Nov 17, 2011 | 11:07 PM
Wow. You did a good job with that. Do you think I should leave the plastic on to spray it or what?
Old Nov 18, 2011 | 09:13 AM
Just take your time the plastic will come off with a bit of persuasion. The rear bumper plastic pieces fit fine on mine it was the front plastic valance that was tough to get back on with the line-x on it.
Old Nov 18, 2011 | 09:27 AM
Vette454's Avatar
As was mentioned , just take your time and you will prevail. A couple of the bumper brackets are in the way of some of the push through tabs. Take em off and you will be able to get to them. I do paint and body for a living and have done this many times. I find an angled long nose plier works great to grab them and squeeze them with. Squeeze the tab together whilst pulling up on the plastic part.
Old Nov 18, 2011 | 09:29 AM
Carolinaboy32's Avatar
This^^^!
I did not and regret it
Old Nov 18, 2011 | 12:06 PM
I'll see what I can do with it
