Flawless Spark Plug Swap
Old Jul 31, 2011 | 07:05 PM
nickbrumaghim's Avatar
I just changed my plugs with out any problems. I have 146k on the truck and had waited for a drop in economy before electing to do the swap. The MPG never dropped and I just felt bad having gone 46K over the schelduled maitenance, so I decided to go for it expecting the worse. All eight came out in one piece. I did this with a warm engine. I cracked the plugs loose about a 1/4 turn, and hit each hole with a moderate spray of CRC pentrating fluid. I then let it sit for no more than 15 minuets and I dove in. I was cautious to stay centered over each plug, and did not allow the extension to deflect if at all possible. I worked each plug back and forth. When the resistance seemed to peak I would tighten the plug a half turn or so and then proceed removing.
Old Jul 31, 2011 | 08:20 PM
risupercrewman's Avatar
Nice!
Old Jul 31, 2011 | 10:51 PM
DSGSTX81's Avatar
You are to be commended, suh! (sorry, my Southern accent had to come out.
Old Jul 31, 2011 | 11:07 PM
Good job! Does the truck run better?
Old Aug 1, 2011 | 12:03 AM
It did improve the throttle response quite a bit. I honestly didnt expect that I would feel any diiference, as the old plugs were still in pretty good shape. The amount of errosion was not bad considering how long I ran them. It is a work/personal rig and I drive 30+ K miles each year. I get 16-17 MPG when mostly on the free way. We will see after a couple days on the road if I gain any fuel ecnomy.
Old Aug 1, 2011 | 12:39 AM
MTM Ford's Avatar
That's good to hear!
When I did mine I didn't notice any increase in mileage but it did change the way it ran for the better.
Old Aug 1, 2011 | 04:14 PM
michrech's Avatar
Worried...
...this thread kinda has me worried. I just purchased a 2005 F150 XLT two days ago. Is there a known issue in removing the old spark plugs in these trucks?
Old Aug 1, 2011 | 04:17 PM
Use the Advanced Search in the bar at the top of the page. Enter broken spark plugs and you should have lots to read.
Old Aug 1, 2011 | 04:25 PM
Start reading and searching>>>>click link>>>https://www.f150online.com/forums/ar...y-writeup.html
I use an impact and techron.....
Old Aug 1, 2011 | 05:33 PM
michrech's Avatar
In reading the thread you linked, it seems everyone that's having issues has the V8... Mine has the V6. Am I going to run into the same issue? I attempted to search "v6 broken plugs" and the search system removed it for being too common...
Old Aug 1, 2011 | 05:37 PM
It is only the 5.4 3v manufactured between 2004-2008 that has the issue
Old Aug 1, 2011 | 05:45 PM
michrech's Avatar
Whew!
(giant sigh of relief here)
Old Aug 1, 2011 | 06:28 PM
It's really not that big a deal now
Old Aug 1, 2011 | 06:43 PM
Cake walk....
Old Aug 2, 2011 | 12:08 PM
kchyde's Avatar
Nick, what plugs did you put in? OEM?
