Clunk...
Old Jun 9, 2011 | 07:39 PM
Clunk...
OK guys and gals, a little help here...
Trying to diagnose a rear end clunk noise. It happens sometimes while slow turning with or without brakes on, turning over uneven street junctions or slowly entering a driveway. I can have the truck in park w/brake on and push either rear tire back and forth and hear a clunk. I thought for the longest time it was the slip yoke but it isn't, though I can feel it on take off and slow down, just without a clunk noise. Everything looks tight suspension wise but I guess I need to get under there and torque everything down.
Got any idears?
Old Jun 9, 2011 | 07:56 PM
MTM Ford's Avatar
Not sure if this could be the cause or not but would it be possible the axle bearings could be bad?
Old Jun 9, 2011 | 07:59 PM
No bearing noise.
Old Jun 9, 2011 | 08:29 PM
buckshot85's Avatar
i'm having the same problem thought it was my lift got everything retorqued but no help i've had it about 5-6 months now and still no luck. does it happen all the time? mines just on and off
Old Jun 9, 2011 | 08:31 PM
Mine is random too.
Old Jun 9, 2011 | 08:39 PM
buckshot85's Avatar
For the longest i thought it was balljoints or tierod but i've narrowed it down to the rear. I'm wondering if the bushings have to much play in springs.
Old Jun 9, 2011 | 08:41 PM
I was thinking maybe the leaf u bolts are loose. I need to get under there and retorque like you did and re-evaluate. Just hoping someone has some insight. :o
Old Jun 9, 2011 | 08:51 PM
buckshot85's Avatar
agreed good luck
Old Jun 9, 2011 | 08:53 PM
darkstar_420's Avatar
how many miles do you have? also pull the plug on the diff and look for metal shavings maybe?
Old Jun 9, 2011 | 08:56 PM
fatty4x4's Avatar
I did have a rear end bang/clunk. It was the rubber bushing in the rear shock had separated from the shock cause the rear shock to shift/bang around. You could give that rear shock a twist and see if it is moving.
Old Jun 9, 2011 | 08:57 PM
101,xxx miles. Rear end has been serviced within the last 20,000 miles or so, so I'd assume it is good. No rear end whine and no rear end clutch pack issues.
Be nice if it was a shock since I have some new ones waiting to be put on. lol
Old Jun 9, 2011 | 09:01 PM
get a wrench on the shackles, u bolts, shocks, see if anything its loose maybe. did you check the u joints?
Old Jun 9, 2011 | 09:05 PM
The u joints look OK, didn't see any abnormal play when I was muscling the truck around from underneath.
Old Jun 9, 2011 | 09:07 PM
buckshot85's Avatar
dang i only have 63k and having the same problem lol
Old Jun 9, 2011 | 09:15 PM
My miles are ~90% highway though. Not as many stop/starts as most.
