Clunk...
Old Jun 9, 2011 | 09:22 PM
fatty4x4's Avatar
When I had to replace my front u joint it wasn't obvious by physically moving it around. The way it became obvious was by driving forward, stopping, putting it in reverse and giving it gas to make it clunk and repeating. Forward then reversing seems to change the drive angle causing the clunk.
Old Jun 9, 2011 | 10:35 PM
U-bolts or u-joint....
Old Jun 9, 2011 | 10:46 PM
I guess I'll be checking both. Good thing I have a serviceable drive shaft.
Old Jun 9, 2011 | 11:06 PM
I had the same problem and about 3 weeks later the left rear shock broke.
Old Jun 10, 2011 | 09:25 AM
jr105's Avatar
I had the "clunk" exactly as you describe and tightening the shackle bolts cured it.
Old Jun 11, 2011 | 03:09 PM
I'm thinking it has to be loose hardware or a loose shackle since it made the clunk/pop noise when I got in the truck this morning.
Old Jun 11, 2011 | 04:19 PM
darkstar_420's Avatar
get under there and start tightening damnit LOL
Old Jun 11, 2011 | 05:21 PM
risupercrewman's Avatar
I would go ahead & put on the new rear shocks & then re-evaluate from there.....
Old Jun 11, 2011 | 06:12 PM
I'll re evaluate in the morning. 98* out right now.
Old Jun 28, 2011 | 07:16 PM
I've tightened everything except the shocks.
Still making the sound. It's a hollow-ish sound if that makes any sense. :o
I can repeat the sound when making quick slalom type turns in succession. This has me stumped. Shocks could cause this sound but they work fine, but could be loose. I sure hope this isn't axle shaft and/or rear wheel bearing related. No signs of leaks anywhere.
Old Jun 28, 2011 | 07:24 PM
mkinttrim's Avatar
I get a single pop when going side to side (fairly hard ) from time to time. Thought it was my lugs but they were tight. I'm beginning to think its the lower ball joints as they feel dry as hell.
When I had truck in the shop for the air bag recall 6 months ago or so they did a multipoint inspection and said that the lower ball joints show wear but tires arent wearing bad at all.
Old Jun 28, 2011 | 07:28 PM
All my front end components are new. Front is tight, rear rides well. No noises other than this one. Smooth as butter, just pops and/or clunks on a few types of turns.
Old Jun 28, 2011 | 07:30 PM
Justin_w32's Avatar
Mine has the same random clunk. My first thought was shocks or leaves, mine does it when I pull into my driveway its kind of a steep angle.
Old Jun 28, 2011 | 07:33 PM
mkinttrim's Avatar
Maybe sway bar links?
Old Jun 28, 2011 | 07:34 PM
I swear it sounds like it's coming from the rear. I'll have a look at them now too this weekend.
