Tires Fit? pls help asap!
Old Mar 1, 2011 | 09:07 PM
Cuz's Avatar
Cuz
I have a 2006 SCREW F-150 4x4. I have 1.5" AutoSpring level kit on the front and 3" blocks on the rear. I currently have 285/70/17's on it and have no rubbing issues but am in need of new tread. Found a good deal on some low mileage BFG AT's but they are 315/70/17's. Will these fit without any rubbing or problems?
Thanks!
Old Mar 1, 2011 | 09:19 PM
06bluemeaniexl's Avatar
https://www.f150online.com/forums/su...ch-wheels.html
Old Mar 4, 2011 | 11:27 PM
jerrybizzle's Avatar
It seems searching this forum that u may have slight rubbing with the 1.5 inch kit. Most seem to have 2.5 or 3 inch leveling with that big of tires. Although they will mount on stock rims if u go to their website they usually recommend an 8 inch wide minimum rim. Stock is 7.5. Sure it can be done but just letting u know that is probably what they recommend with the wider tire. I found good tire deals on discounttiredirect.com and free shipping. Not sure how great the deal is on the bfgs. I actually want the same kit u have as I have 285/70/17 tires with no level. Don't want to go bigger as I tow in the summer a travel trailer.
Old Mar 4, 2011 | 11:35 PM
It appears u have all terrains. Nitto makes some sizes that would fit u great. The Terra grappler comes in 295/70/17, 285/75/17 and 305/70/17. With the stockers I would look into the 285/75/17. They are about 34 inches tall and no wider then Ur current. Toyo also makes the 295/70/17 size.
